0 Members and 25 Guests are viewing this topic.
rakarskiy
Solid-state electromagnetic rotor
https://patentimages.storage.googleapis.com/eb/0c/07/d463fa60c9f935/WO2021063522A1.pdf
https://www.youtube.com/channel/UCybmZRY4-LZi3ZHsqByvOwQ  ?????????
If a guy instead of a jumper core with a removal coil, made an internal armature with grooves, and wound the generator winding, he would get the desired design of a solid-state transgenerator. By the way, he just needs to remove the core and make a block of removable windings fixed using the slots of the generator.
https://youtu.be/Pnein7agC_8
QuoteWe have already created the first HES prototype for cell phones. This technology is scalable for all imaginable applications... Imagine one day never having to charge your phone or computer again!
https://patentimages.storage.googleapis.com/f1/73/db/bddc31a19a8100/CA2357550A1.pdf
https://rakatskiy.blogspot.com/2022/05/electric-solid-state-generator-tg.html
rakarskiy
What is the basis of the action of the generator, leading to the effect of overunity. Just read an excerpt from a physics textbook:
Quote"Ferromagnetic materials, such as iron, cobalt, nickel and their alloys, steel, etc., are widely used in various electrical machines and apparatus to amplify the magnetic field and give it a certain shape.
If a ferromagnetic material is placed in a coil and an electric current is passed through its turns, then under the influence of the magnetic field created by the current, the material is magnetized. This means that the material has its own magnetic field, obtained as a result of the addition of magnetic fields (magnetic moments) of individual atoms.
A change in the current strength in the coil leads to a change in the strength of its magnetic field H, which causes a change in the magnetic induction B in the core of this coil.
The state of a material in which a further increase in the magnetic field strength does not lead to an increase in its magnetization is called magnetic saturation.
The magnetic properties of materials are characterized by their absolute magnetic permeability μa. It is determined by the ratio of the magnetic induction B to the magnetic field strength H and is measured in henry/meter (gn/m): μa = B/H
Absolute magnetic permeability of vacuum μa = 4π 10-7 gn/m. For air and other non-ferromagnetic materials, it slightly differs from μa and, in technical calculations, is taken equal to 4π · 10-7 gn/m.
Since the absolute magnetic permeability for vacuum and the above materials is practically the same, then μa is called the magnetic constant μ0.
The absolute magnetic permeability μa of ferromagnetic materials is not constant and is many times higher than the magnetic permeability of vacuum.
The number showing how many times the absolute magnetic permeability μа of a ferromagnetic material is greater than the magnetic constant μ0 is called relative magnetic permeability μ or magnetic permeability for short: μ = μа / μ0
With the same magnetic field strength, the magnetic induction in steel is greater than in cast iron. This is due to the fact that the magnetic permeability of steel is greater than the magnetic permeability of cast iron. The magnetic induction is directly proportional to the field strength H and the absolute magnetic permeability μа of the magnetized material: B = μаH
Example. The magnetic field strength of the coil is H = 750 A/m, and the absolute magnetic permeability of the core is μа = 0.0008792 gn/m. Determine the magnetic induction of the core.
Decision. Magnetic induction B = μаH = 0,0008792 · 750 = 0,65 T.
Since 1 T = 10,000 gauss, then 0.65 t = 6500 gauss."
Let me explain what is "surprising" in this issue, which everyone knows about and no one sees point-blank, that this is overunity. Imagine the winding of a toroidal transformer with an iron core and an air frame.
The intensity of the magnetic field, which is created in the ring core when current I flows through the winding, can be calculated by the formula: H = N*I/l, where: N is the number of turns; I - current strength in the wire, Ampere; l is the length of the ring along the midline, meters.
Let's say we have 75 turns, with a current in the wire equal to 1 Ampere and a length of the middle line of the ring core 100 mm (0.1 meter): H = N * I / l = 75 * 1 / 0.1 = 750 A / m
Source voltage U = 5 V, power is P = UI = 5 * 1 = 5 W
Absolute magnetic permeability: air = 1.25663753 * 10(−6) (0.000001257) gn / m, core = 0.0008792 gn / m, it remains only to calculate the magnetic induction at a magnetic field strength of the winding equal to 750 A / m:
Without core: B = μаH = 0.00000125663753 *750 = 0.000942478 T,
With a core: B = μaH = 0.0008792 * 750 = 0.6594 T.
With the same expended source power of 5 W, we obtained an increase in the resulting magnetic induction by 700 times.
Cadman
Quote from: rakarskiy on May 04, 2022, 07:35:41 AM
Hi Rakarsky,
This is exactly what I have been experimenting with for the past 8 months. I'm glad someone else sees it for what it is, thanks for speaking up.
rakarskiy
We take the company's patent,
and we compare it with the principle of the Figure generator. It is more logical to alternate electromagnets by polarity.
I congratulate Robert Holcomb on the realization of an idea that is more than 110 years old.
By the way, the patent rights to the Figuerа Generator belong to the World Bank.  Such simple information, if suddenly everything collapses with development, as always.
Ufopolitics
Hello to All,
Text books related to magnetism, plus properties...are full of BS, and lots of confusing terms...for example, a part of the text cited prior by Rakarsky:
QuoteIf a ferromagnetic material is placed in a coil and an electric current is passed through its turns, then under the influence of the magnetic field created by the current, the material is magnetized. This means that "the material has its own magnetic field", obtained as a result of the addition of magnetic fields (magnetic moments) of individual atoms.
Negative to the "affirmation" that the "Material (Iron Core) has its own Magnetic Field" !!!
The Magnetic Field, INVOKED by passing currents through a SPECIFIC WOUND copper wire that we all know as "COIL" ,  generates A MAGNETIC FIELD (JUST ONE), which is TRANSFERRED to the Iron Core Mass, and going into details, to align the specific domains.
A Magnetic Field is a SPATIAL SPECTRUM FIELD, which is INVOKED (so far by ancient knowledge, as the only way we all know so far...) based on currents flowing in a continuous spiral shaped geometry of any given conductor, period.
This Field can "transfer, redirect, jump to", etc,etc to any given ferromagnetic material...
But, still, even in another material...whether by transfer, redirection or else...is the SAME ORIGINATED FIELD.
From "my own text book"... ;D
Cheers
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
