Cadman
Quote from: onepower on May 07, 2022, 04:59:39 PM
I'm still working on the flowing magnetism problem and it's a real mind bender. The problem relates to a lack of true field rotation because the magnetic field is a property of space separate from the source. It can expand/contract from the source and move with it but not rotate with it.
I'm still trying to produce a true field rotation but I haven't quite put all the pieces together yet.
AC
There you have put your finger on the issue with the Figuera generator. Years ago when several of us, including Ufo, built different versions of it I came to the same conclusion. The field needs to actually move in space, not just expand and contract with varying coil intensities. I built a DC variac to eliminate the resistors but that didn't make much difference either. It generated some current but not enough. It was still just expanding and contracting coil fields like a transformer.
I gotta hand it to Ufo, I think he has the right approach in this respect. He is actually rotating the field of an armature. Yes it's still being done by increasing, decreasing, and changing polarity of the armature coils, but what ends up rotating is the field from the -iron- in the armature. That magnetic field never dies, it's pulled around the armature by the coil fields, actually rotating, not just changing vectors.
That's my 2 cents anyway.
Cadman
listener192
Holcomb states in WO2010079422A9, that his cogeneration device may use switched DC, or three phase AC on its rotor coils.
L192
Ufopolitics
Hello All,
I have been testing an AC Blower Motor Stator (as is, OEM windings) with my newer 20 tooth, 16 coils rotary field armature...
The rotary Field works beautiful, however the induction motor stator wiring sucks...like Rakarsky said before..."A good Motor will make a bad Generator...and so on...a good Generator will be a bad motor..."
This windings are not suitable for generating right, too small gauge, so, higher resistance...plus it is not wound as a Generator is...
Unfortunately, my Generators Stators are greater in diameter than the armature is...
I get much higher voltage at output than input, but lower amps...this is too fine wire on stator, like 28 or 30 gauge, max is like 20 one winding.
The behavior of the Rotating Field is excellent, having in mind all the related spec's when driving these fields this way.
1- The higher the RPM's of the Field, the lower the Input Amperage goes...and viceversa
2- The running voltage of the field (Input) should always be greater than the amperage, in an average like 60V to 1.0+ Amp...
I will have to remove all windings off Stator Motor and rewind it with 14-16 gauge, plus the way it is wound for generators...
I will be posting detailed info about all this on my Thread:
Energy Generation by Moving the Virtual Field
Cheers
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
rakarskiy
Ufopolitics, the winding of the generator must be calculated. Everything is calculable, you need initial data. We take one turn in the generator winding and determine the optimal EMF. Then you need to calculate the phase of the generator, the number of turns and the cross section, but this has its own characteristics. Read my material about Ampere power, there are examples of how I calculated the generator. The problem of many, they do not know how the current strength is formed in the network. Sometimes qualified electrical engineers cannot answer the simple question of how the generator EMF differs from the mains voltage under load connected to the generator.
You are very close to the goal, it remains to deal a little with the generator winding and the rules for its calculation. You need to calculate according to the maximum allowable load. Not as much as you want, but as much as you can take.
https://rakarskiy-narod-ru.translate.goog/publ/free_energy_systems/rezultirujushhaja_sila_ampera/3-1-0-146?_x_tr_sch=http&_x_tr_sl=ru&_x_tr_tl=en&_x_tr_hl=ru&_x_tr_pto=wapp
Ufopolitics
@Rakarskiy,
Quote from: rakarskiy on May 08, 2022, 02:34:04 PM
Ufopolitics, The winding of the generator must be calculated. Everything is calculable, you need initial data. We take one turn in the generator winding and determine the optimal EMF. Then you need to calculate the phase of the generator, the number of turns and the cross section, but this has its own characteristics. Read my material about Ampere power, there are examples of how I calculated the generator. The problem of many, they do not know how the current strength is formed in the network. Sometimes qualified electrical engineers cannot answer the simple question of how the generator EMF differs from the mains voltage under load connected to the generator.
Thanks, I know, Rakarskiy,
However, I have already wound some generators as existing number of turns or by wire length calculation...
I just want to "prove a concept"...I have already proven part on the small universal motor assembly from the RYOBY Tool...but not enough.
I know, as I am so freaking sure it will work!!
Calculations for winding from scratch a generator is whenever you need specific power output, or specific voltages and amperages...I am not being "picky" at this time, since it is just for a testing demo.
Rotating the Field at a normal speed, as being able to "see" the rotation strength while using the correct spec's related to V & A is already done...
I have a spanish friend on YouTube that have also being doing this testings, not successfully, because he is overkilling the drivers...too much power to drive just the brushes...we do NOT need that much...
However, He is using steel bars inserted in between stator-armature, because rotor is smaller than stator...and it works...so, I will be doing same thing on a 900 Watts Generator Stator I have...just to observe output.
Thanks for your counseling!!
Ufopolitics
EDIT: I had issues with internet...but I already started taking apart the piece of sht stator...LOL...What does not work...it needs to be replaced with the correct winding, shape form and right gauge...see image ;D
―Leonardo da Vinci
