hartiberlin
@Solarlab
why don“t you convert your Simulation output pics to MP4 Video files and post them on Youtube ?
For longer and looped display you could put several sequences in a loop and just add them to the MP4 Video file.
Then you can store all your magnet simulation files as animation on Youtube.
No need to go the GIF animation method which always needs bigger File size...and is hard to store
in a forum...
There are freeware software packages out there that lets you convert from GIF or JPEG pictures to MPEG4 Video files
which Youtube accepts.
Hope this helps. Regards, Stefan.
ramset
"Solarlab" Has not been posting here ,
However I believe that may change..?
Or his work will find a path to interested parties here
And elsewhere!
Regardless,
At another topic this technology to assist in research is being shared
Solarlab
The analysis is being done using Ansys, Comsol, JMag and CST. As mentioned, and shown, CST is easiest since "Excitations" can be added at the "LT-Transient" phase without resorting to a "Circuit" layout to sequence the pole coil/windings.
End quote
As mentioned prior in this thread ,
additional HES discussion is here,
https://www.overunityresearch.com/index.php?topic=4261.msg98927;topicseen#msg98927
(Above topic hosted by AllCanadian)
Goal is to figure a hosting method which will benefit all who wish to observe and explore this
Technology being shared by Solarlab !( **tech has huge hosting load on a forum venue ..
Looking for solutions!!)
And Solarlab is doing very specific analysis on Holcomb Energy Systems and has zero extra time
For managing a forum topic / discussion!
(Trying to figure a solution to assist him and benefit all !
Respectfully
Chet K
Thanks Grandma
kolbacict
if the coil is moved past the magnet along one coordinate.
And at this time, the magnet is moved past the coil along a different, orthogonal coordinate.
We will no longer have a two-dimensional interaction, but a three-dimensional one.
Has anyone used this?  Might will be something interesting...
Just thoughts.
Lunkster
Suggested Upgrades for Holcomb motor systems:
Current system design deficiencies:
The physical design is for generators that are in motion.  This creates a lot of limitations for the motor.
1.)   The two stators have different dimensions due to the different circumference they are designed in.
2.)   The inner stator electromagnets have more interaction with the adjacent electromagnets due to the confined area they are built into.
3.)   The distance between the rotor and stator assemblies are not adjustable but fixed between each other.
4.)   It is hard to measure parameters in different locations between the rotor and stator assembly due to the physical construction of the generator.
5.)   It is harder to perform maintenance or make changes to the rotor or inner stator assembly on this design.
Upgrade physical design of the stator and rotor assemblies:
3 Disk assembly:  Disk 1 stator 1, Disk 2 rotor, Disk 3 stator 2
1.)   Both stators have the option of being designed with the same physical configuration.
2.)   The interaction between inner stator components can be reduced with the disk configuration.
3.)   The distance between the rotor and each stator assembly is easily adjusted using disk assembly construction.
4.)   It is much easier to place probes into place between the stator and rotor assemblies.
5.)   It is much easier to perform maintenance or make modifications on a disk motor design.
Addressing the power and control system of the Holcomb energy system.
The computer control system has so many more options than the mechanical options shown so far.  Here is the reason why.
. It is important to be able to adjust the duty cycle along with the power cycle of the power to each coil.  This will make a big difference to the efficiency of the generator performance.
.When you look at efficiency curve of the core material being used in the motor.  It is important to operate the generator within the best operational portion of the curve.  I believe that by keeping all the stator coils with a small current in them to keep them at the lower best part of the curve as the off point is something to try.  Then with the coil needs to be switched ON, then the switching would raise that current level of the coil so that the core reaches its best gain portion of the curve could be had.
The other power timing that Holcomb has already called out should be used first for the testing of the prototype.
When I was talking about keeping in the range of the core efficiency and gain I was thinking about a core that does not flip its polarity during the operation of the generator.
Since a generator operates on changing flux in order to generate electrical energy, we do not have to flip the polarity in the core in order to do this.
Instead of having to alternate between 4 north poles and 4 south poles for the 16 coils in each stator, we can alternate between low strength north poles to high strength north poles.  What this does is to keep the core from flipping polarity.
Now the low strength polarity could be done by the self-induced magnetism that would already exist in the core, or if we needed more strength in the core to be in the best part of the curve for the low north pole setting then we could either apply a small current to the power stator coil, or we could have a small or a few small week permanent magnets built into the cores used in the generator to give us that bias.
The changing strength of the stator coils would create a changing magnetic flux through the rotor coils in order to produce the electrical energy from the generator.  This would be done without the flipping magnetic polarity in the cores of the generator.
After watching the video on the crystallin structure flipping in the core material, I thought that this new approach may be what Dr. Robert Holcomb was talking about in his videos.
I have a question;  would switching the power to and from the stator coils at the power line instead of the return line reduce the back-EMF in the coils?
Jay Lunke  Known as Lunkster
