0 Members and 31 Guests are viewing this topic.
ramset
Solarlab is now able to post here ( last week or so )
Also he can have a moderated board here for his amazing
Simulations.
Where he is sharing at OUR forum is a moderated board ( AllCanadian moderates there if needed)
I do believe Solarlab has very limited time to post all this info,
So it's good to give links back to his work for now !
IMO the more eyes the better for this simulation
Perhaps others of like talent can also participate!
Respectfully
Chet K
Thanks Grandma
rakarskiy
The whole process of designing an electromagnetic solid-state generator, as well as a mechanical one, consists in the correct calculation of the magnetic circuit. If in a mechanical electric generator the initial magnetic flux of the rotor is "constant" and the calculated saturation level is reached at the corresponding magnetic induction, then in a solid-state rotor this process must be controlled. The effect of conditional constancy of magnetic saturation is achieved. switching of electromagnets according to a special algorithm. This is a property of parallel and series closure of the magnetic circuit, the subsequent closure of the magnetic circuit. A solid rotor is an element of a combination of parallel connection of electromagnets while maintaining a constant level of magnetic flux and level of magnetic induction.
In a closed inhomogeneous magnetic circuit, the magnetic flux is not uniform. If a design engineer does not know this, he has a fake diploma.
The subject of designing magnetic circuits is extremely complex. At times - two, in this direction it is difficult to understand. Magnetic induction is a non-linear function, it is the magnetic field itself. The magnetic induction is maximum when the magnetic permeability in the material where it is manifested is already minimal. There are a lot of interesting things there.
The Holcomb Energy System is absolutely real and cloneable. The design engineer should understand this. Believe me, a correctly set technical task, the result will be. Because I think that the ERA of solid-state electric generators has begun ..
Sincerely.
kolbacict
Quote from: Ilya Tsimbaluk on May 18, 2022, 02:16:14 AM
I expect that with a non-linearly changing current in the inductance, which implies a parametric process, the graph should be something like this. But for this, I would like to talk with a person who could recommend a CAD system in which one could set a time-varying inductance
Any inductor with a ferromagnetic core will be non-linear in time, right?
The magnetic permeability of the material changes all the time from the current flowing in the coil.
Feb2006
stivep
Quote from: rakarskiy on May 15, 2022, 02:54:47 AM
In vain you staged a controversy! Which shakes the topic, the wrong steppe.
Dr. Holcomb has a patent for a solid state rotor (this is essentially an analogue of an electromagnetic rotor for electromechanical machines).
https://patentimages.storage.googleapis.com/7d/d1/d7/018fe4892a4d9e/US20190238011A1.pdf
Rakarskiy ,при всій повазі, це має бути хтось, хто є реалістичним тут.
або, якщо бути точніше - той, хто дивиться на факти, а не на фантазії
«Сла́ва Украї́ні!»
____________________________________________
quoted by you link is not a patent is an application.- please correct me if I'm wrong.
In this link below there are only applications of that medical doctor who wants to be inventor in physics.
However there is one patent:
Derivatizing organometallic halides Patent number: 7238824
https://patents.justia.com/inventor/robert-holcomb
Type: Grant   Filed: June 7, 2004   Date of Patent: July 3, 2007   Assignee:  Agilent Technologies, Inc. Inventor: Nelson Robert Holcomb
it is Grant probably because it was assigned to Agilent ( former Hewlett-Packard).
In a few sentences can anyone explain to me :
1. what is the energy coming from - in Holcomb so-called invention?
2. what is the form of initial energy?
3. What that energy is changed to?
4. where is the gain and what is the nature of the gain of net energy if any?
so the bottom line is: I see some sort of medical doctor with his 2004  till 2010 patent applications
mostly abundant or rejected who changed the name
for the fresh one: HOLCOMB SCIENTIFIC RESEARCH LIMITED,
Incorporated: 2017-02-23 and marked as inactive.
https://ie.globaldatabase.com/company/holcomb-scientific-research-limited
QuoteThe company began trading on 23 February 2017 and employs 4.
Patent application is not a patent yet - anyone of you can file patent application .
so now they have that, the only patent application the ever produced for that inactive entity
mentioned here by rakarskiy
https://patents.justia.com/assignee/holcomb-scientific-research-limited
we may assume that trading was their source of money.
some criticism is expressed here:
https://www.reddit.com/r/Scams/comments/6kk7aa/holcomb_scientific_research_llc_scam/
Conclusions:
all of the listed above, doesn't prove or disprove the concept.
However there is only concept and there is no patent at the present time for the device in question.
The so-called inventor, since 2004 didn't convince the general public and is in business of publicly trading
his own stock I assume.
Wesley
