0 Members and 38 Guests are viewing this topic.
rakarskiy
stivep, check out this post here:
https://overunity.com/19069/holcomb-energy-systemsbreakthrough-technology-to-the-world/msg566716/#msg566716
and another patent that the guy is experimenting with
https://patents.google.com/patent/US8629588B2/en?oq=8%2c629%2c588
I hope you know what the letter "B" means at the end of the patent number.
I've never been interested in what's being pushed into the explanation of technology. I was interested in the very possibility of such a device. I understand how it works and make a clear case for workability. Womprs can Holcomb monopolize the technology? No, there is nothing that is unknown to science. It all comes down to good engineering design.
Magnetic amplification in electrical steel is one of the disciplines taught in educational institutions where electrical engineers are trained.
The magnetic field that is created in the body of the steel magnetic circuit already has its own potential, which induces an EMF in the phase conductor. This field is much larger than the magnetic induction from the winding of the excitation electromagnet, the permanent rotor electromagnet.
How Holcomb (more precisely, the team of engineers who worked on the device) solved the issue with the resistance of the fields, which already forms the phase winding under load, is not disclosed in the patent or in the explanations.  This does not mean that the device is not working.
The fact that they want to hide this technology for another .... the number of years is extremely clear. I won't be surprised if Holcomb announces the unavailability of his devices and dives soon.
Україна переможе! Україна – це Русь. Росія це вигадана країна. Є такий наказ "Ванька, що не пам'ятає спорідненості".
Вони не вміють будувати, тільки грабувати і вбивати. Все добре, що можуть згадати в СРСР було за Брежнєва, а Брещнєв це українець із провінційного індустріального містечка возі міста Дніпро.
Beginners Mind
A patent attorney just informed me that Dr. Holcomb's patent application of Aug 1, 2019, so often referenced in this thread, is now a granted US patent dated May 17, 2022, just 6 days ago.
The US patent number is US 11,336,134 B2 and not yet showing up on the Google patent search.
The cover page art was swapped for one of the more recondite embodiments and there are some minor, non-material edits in the claims at the end.  But otherwise the granted patent is identical to the Aug 1, 2019 patent application in my review.
rakarskiy
Consider one moment that explains the operation of both a mechanical electric generator and a solid state one. Rotor and stator made of electrical steel have relative magnetic permeability. This property refers to the magnetic resistance of the steel material to the electromagnetic field of the excitation coil (magnetic field strength). Magnetic induction refers to the magnetic field generated in steel. With the growth of the magnetic field, as an independent structure, under the action of electromagnetic, the magnetic resistance of the circuit grows, this property is explained precisely by the appearance in the core of its own magnetic field, which is many times greater than the magnetic induction of a coil without a core. This process is non-linear. It is this field that is the source that induces the EMF in any mechanical synchronous generator (a circuit from my book, with a graph of permeability and induction) or the considered solid-state electromagnetic generator.
Holcomb did not dissemble that electrical steel is the source of energy, but for some reason he did not indicate, that he used the property of electrical steel to amplify a magnetic field a certain number of times.
Everything else is an engineering solution or technology. The technology of controlling the magnetic field, which is excited in electrical steel, with its movement (rotation) in the generator stator, without mechanical force to rotate the rotor.
Думаю, вопрос о том, что является источником в Энергетической Системе Холкомба, закрыт. Действие его устройства заключается в преобразовании энергии первичной цепи в энергию, вторичной цепи - с увеличением выходной мощности, по отношению к входной.
pix
Quote from: rakarskiy on May 24, 2022, 02:42:27 AM
This is known by every secondary school pupil, attending physics lectures.  :)
Ferromagnetic materials do amplify magnetic field, of course. But it works both way. Once in output solenoid starts flowing a current, it creates opposite magnetic field that is amplified the same way, and opposes cause of change- magnetic field from primary coil.
Nonlinearity region of very soft ferromagnetic materials could be only used in setups like Current Transformer in flyback regime.
Only then you could harness ferromagnetic amplification.
Cheers,
Pix
rakarskiy
Hеllo Pix!
There is no counter field there, and this is the big lie of education. The field is strengthening, not opposing. To understand this, you need to check the polarity of the core to the magnetic pole at different distances. to distinguish what is primary and what is secondary in a given action. This was chewed up and used in his invention by Robert Adams. Do not confuse the magnetism of materials with the ampere force.
If there were counter flows in the core, the resultant would be zero. the electromagnetic moment would be zero or close to it. In fact, the flow is maximum. There is another position that is not considered in education, this is the mechanism for inducing EMF from an external field, and its interaction with the field of a conductor under current. So what every student knows is critically insufficient for the design of a solid-state and mechanical generator
