Quote from: pix on March 23, 2022, 10:56:09 AM
Who is saying that transformers or generators are doing this?
Flyback converter is doing this.
Boost converter is doing this.
Joule Tchief is doing this .
Cheers,
Pix
Pix                                                        compared                            Cadman
Flyback,Boost,Joule thief   machine         versus                      ordinary/conventional,standart machine
% sell quote from all  converters                                                 % sell quote from all converters
Newbie versus professional technical standart,industrial and or lab R&D  view and meaning !?
wmbr
OCWL
Cadman
I said ordinary transformers or generators are not doing this
QuoteFlyback converter is doing this.
Cheers,
Pix
Are they? Completely? Think carefully before answering.
And while you think about it, ask yourself if this was really the most salient point in my previous post.
Cheers to you too.
Cadman,does He not shake the " principles of thermodynamic building " to write about
" energy is  ..... "
" energy is not ..... "
expand-/compress -
multification-/diminuation -
        able ! (?)  8) ,if ......   https://www.youtube.com/watch?v=tmQhEuDIhy0  CONDITION/-ING !
Sincerely
OCWL
p.s. :  https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20010710&CC=US&NR=6259347B1&KC=B1#
                                         pseudo conductor  superconductor ultraconductor   hyperconductor
Without proper cooling the efficiency and reliability of these transformers and motors are considerably reduced.
Another object of this invention is to provide a cooler operating high power electrical device that is of light weight, low cost, higher power density, and highly efficient design.
    These and other objectives are obtained by placing thermal conductive strips between the turn layers along the axis and perpendicular to the turns of an high power electrical device, such as a transformer or motor, which extends outside of the windings or between the laminates of the core.
The excess heat is conducted outward from the interior of the device along the strips to the outside of the device's windings where it is extracted from the protrusions by means of a highly thermal-conductive potting compound that has a short thermal path to a small heat sink.
"........   an anisotropec material that is highly efficient in conducting heat along the fiber orientation which is unidirectional.  .....
" ...... This invention allows for the reduction in size of a high power transformers by a factor of 4 to 8 and a reduction in weight by a factor of 4 to 6, and an increase in power density by 5 to 10 in power. The efficiency of the transformer is improved by maximizing the heat transfer from the transformers interior and minimizing voltage breakdown. ...... "
" ........ therefore a control device such as a timer (not shown) or thermal switch (not shown) may be integrated into the transformer 20 package to either increase the thermal conductivity or decrease it by switching the thermocooler on or off, as desired.  ...... "
Although this embodiment has been described in relation to an exemplary device such as a transformer, the claimed invention may equally well be utilized in other types of electrical devices where internal heat is a problem, such as motors, modulation transformers, etc. The size of the transformer is not of concern, it may vary from a small transformer used in switching power supplies to power transformers used in electrical distribution systems. Further, the frequency of the electrical current within the devices to be cooled is irrelevant, e.g., 60 cycles to 400 cycles operate the same thermally. High frequency transformers have higher copper losses due to skin effects. This additional heat may also be removed by the thermally conductive strip as set forth in this invention.
    When applied to electrical motors 30, as shown in FIG. 5a, pieces of thermally conductive strip 16 are placed between windings of the motor 30 or interleaved into vertically stacked motor laminations 32, as shown in FIG. 5b. The internal heat from the motor laminations 32 and windings 36 is conducted from the interior of the motor 30 to the outer portions where the heat is then dissipated through the motor case 34 to ambient atmosphere.
https://en.wikipedia.org/wiki/Philadelphia_Experiment
-               https://en.wikipedia.org/wiki/Scientific_law
Ufopolitics
Hello to All,
With all due respect about your expertise on Magnetic Fields and Induction-Induced Fields...
You keep pounding on existing -up to now- Technologies...and yes, Dr Holcomb keeps repeating something we all know...about Steel Properties related to  magnetism amplification...yes, We all know that.
IMHO what He has reached is a way to rotate a DC MAGNETIC FIELD, NOT an AC Field which is rotating just by turning it ON...
HOWEVER, the way an AC Magnetic Field "rotates" is completely DIFFERENT from a Rotating DC Magnetic Field.
And so, actually, an AC Field does NOT actually, physically rotates, but only "Flashes" N-S at a rate of 60 to 50 Hertz...generating the spinning feeling if we insert a metal "Egg" or a Laminated Steel Rotor, it will definitively spin a steel mass. (Tesla Induction AC Motors, 1896-98)
There are many inventors who have played with this scenario of "VIRTUALLY SPINNING DC FIELDS"...I have been also conducting experiments related to this way to induce an Electric Output by Rotating DC Fields...for many years back...
Figuera, back in the early 1900's had Patented his way to achieve this...
Steve Marks, has also played with this...
And many many more...
If You go to this video : https://www.youtube.com/watch?v=Nm1VJ65LcXM
At exactly 0:45 on...you will see an animation of what Dr Holcomb has achieved...a Rotating DC Magnetic Field...including a GRADIENT (Fade IN, Fade OUT) of the Magnetic Fields...
This can be done whether by mechanical commutating controls or by Electronics...FET's...with atenuation circuits to achieve the Fade Effect...
AC Rotating Magnetic Fields will NEVER, EVER, generate this effect...much less, the Fade Effect, Plus the OVERLAPPING Effect.
A simple example of a typical DC Exciter BUT actually moving physically the Magnetic Fields, we can see in a simple Single Phase Brushless Generator...where the Inducing Rotor is comprised by a CLOSED CIRCUIT (Closed by TWO DIODES) of just TWO COILS , generating a North and a South Pole at 180º...and having another CLOSED CIRCUIT COILS at Stator (with an AC Running Capacitor), exclusively to keep Inducing the Exciter Coils at Rotor...
Now, Diodes are there to convert the Induced AC into DC Current at Rotor, which keeps a steady NS-NS polarization of rotor steel core.
This Rotor will not generate nada, if we take off the diodes...just because it would be AC Flashes of magnetic polarization...not inducing nada at Output Stator Coils.
So, what I believe Dr Holcomb has achieved is a way to rotate the DC MAGNETIC FIELDS, with GRADIENT EFFECT, without PHYSICALLY moving the Steel Rotor itself...
Again, I will repeat myself...many has published his findings before...but no one has been able to replicate it...and there must be a specific type of DC Controllers behind these Patents, not explained at all...which are the "secret" behind these disclosed "Breakthrough Invention"...
I am pretty sure, there has to exist another Patent, somewhere, protecting this KEY device, and maybe not even under his name...and not even related to "Energy Induced Generation"...but simply "A New or Novel Type of DC Controller"...
Those are my Two cents here...
Regards to All.
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
pix
Quote from: Cadman on March 23, 2022, 11:57:32 AM
I can tell you this much, gain can be had by avoiding counter emf (Lenz) produced by secondary windings during the magnetization phase of the core primary windings[/size]
That's exactly what flyback converter is doing  :)
