kolbacict
Quotelike Current Transformer in flyback regime.
What it is?
з.ы. Please give me the electric circuit ESMD751L4TXA
There is nothing to eat, you understand? :)
I refused to repair TVs for fundamental, moral reasons.
With TVs, it was easier with documentation. Everything is familiar there.
It was the main source of income.
I'm do not asking for money. Usually everywhere they ask for money.
But I can make it  myself. ;)
p.s.
QuoteUnfortunately this drive has been discontinued for over 5 years and even parts are no longer available.
I would recommend replace with a newer product, see attached i550 cabinet series drive.
Well, I just asked for an electrical circuit diagram for repair, and they sent this... >:(
pix
Quote from: rakarskiy on May 24, 2022, 04:46:43 AM
Hеllo Pix!
There is no counter field there, and this is the big lie of education. The field is strengthening, not opposing. To understand this, you need to check the polarity of the core to the magnetic pole at different distances. to distinguish what is primary and what is secondary in a given action. This was chewed up and used in his invention by Robert Adams. Do not confuse the magnetism of materials with the ampere force.
If there were counter flows in the core, the resultant would be zero. the electromagnetic moment would be zero or close to it. In fact, the flow is maximum. There is another position that is not considered in education, this is the mechanism for inducing EMF from an external field, and its interaction with the field of a conductor under current. So what every student knows is critically insufficient for the design of a solid-state and mechanical generator
Then every transformer should be an OU device.
pix
Quote from: kolbacict on May 24, 2022, 05:15:09 AM
What it is?
Current Transformer I see like a magnetic diode. B field from central conductor is amplified by ferromagnetic material of toroidal core. Current in the coil is prohibited to flow by diode, there is no magnetic counter field in the core
Once current flow in central conductor is stopped, amplified magnetic field in toroidal core collapses and induces bemf in the coil.
Very small B field from central conductor is enough to fully magnetize toroidal core.
There is no Lenz action back to central conductor (magnetizing circuit) from coil on the toroidal core.
In this way we harvest nonlinear region (amplification) of ferromagnetic material.
Cheers,
Pix
Edit. A small air gap in the toroidal core would be beneficial to store more magnetic energy. Could be also distributed.
rakarskiy
Quote from: pix on May 24, 2022, 05:16:29 AM
A transformer cannot be an OU, by definition of action - interturn mutual induction. The secondary winding interacts with the primary winding in the transformer according to the rules of current meshing between parallel wires. The magnetic field of the core cannot be the main transmitting source. An example is the use of a gap in the core, the magnetic induction of the core is sharply down, and the current in the transmission circuits is sharply up.
Feb2006
A test.
Two U ferrite cores, 1primary coil 100 turns ,2 flat coils 10 turns.
All you get is a bad transformer.
Don't think rakarskiy concept is going to work.
You have to consider inductance and reactance.
Holcomb  has a way to reduce those.
Wonder if he is aware of that.
Someone that can figure it out?
Hint: look at the firing sequence he is using.
PICTURES in PDF
