0 Members and 23 Guests are viewing this topic.
rakarskiy
Quote from: Feb2006 on May 24, 2022, 02:46:21 PM
A test.
Two U ferrite cores, 1primary coil 100 turns ,2 flat coils 10 turns.
All you get is a bad transformer.
Don't think rakarskiy concept is going to work.
You have to consider inductance and reactance.
Holcomb  has a way to reduce those.
Wonder if he is aware of that.
Someone that can figure it out?
Hint: look at the firing sequence he is using.
PICTURES in PDF
Well done, gotta check it out. I am also working on the impulse system. But neither I nor you have a magnetic field in the core.
I have a yellow beam, this is the EMF in the groove. (1V = 1A) According to the calculations, it should be 0.35V. In this case, 0.02 V corresponds just to the magnetic induction of the coil without a core.
it turns out that there is no field in the kernel that needs to be obtained.
And the core is like a focused channel of the coil's magnetic induction. But it looks like I'm already close to figuring out how to ignite, this field in the impulse system.
In the systems of Holcomb and Park, Zhe Sun is not an impulse, but a permanent electromagnet with a caterpillar switching function, like a crawling caterpillar.
phoneboy
A test.
PICTURES in PDF
Agreed, similar output layout, check schematic and flux sim gifs.
phoneboy
Sorry, could'nt upload sketchup file of array, too big.  The GIFs are animated, guess you have to download.  Lastly, that schematic is missing a ferrite rod after position 9.
Wayne.
kolbacict
Quotehttps://overunity.com/19069/holcomb-energy-systemsbreakthrough-technology-to-the-world/dlattach/attach/187288/
I understood. This is what is in many switching power supplies to protect against excess surge current. As part of the PWM controller.  And also in my frequency converters for asynchronous
motors, for which you do not give me a diagram.  :)
Quote from: phoneboy on May 24, 2022, 04:50:34 PM
Wayne.
And what does rolamite have to do with it?
Just like a contact switch?
I thought at first that there was a big intrigue hidden there ...
seychelles
PHONEBOY I JUST LOVE YOUR PLAN. JUST BRILLIANT. I WISH YOU LUCK AND GREAT FORTUNE.
