Beginners Mind
Rakarskyi - Thank you tremendously for the links and the photo!  The generator in that photo does not resemble any pictures currently on their website or in their YouTube videos.  I just reviewed them all.  Though it does resemble the generator in their animation.  They have deleted that picture of the generator from their published material.  You have done everyone a great service by saving it.  Clearly it contains information they would rather not have publicly disclosed.
The generator in the deleted picture has two "rotors!"  There is an inner rotor, a 3-phase stator, then an outer rotor.  The patent shows only an inner rotor.  An outer rotor may be critical to fully understand why the device works and for builders attempting to replicate it.  Having the benefit of this deleted picture, I believe the photo I previously posted and labeled bottom view of rotor is most likely a picture of a 3-phase stator before being sandwiched between two rotors.
Thank you again for saving and sharing that photo.  Fabulous!  Geometry and winding pattern of the entire generator is now clear.
rakarskiy
Magnetic Flux does NOT flow!
Magnetic Flux has a attraction vector, to connect in a "ring"!
If the current is open then the current has poles! The vector is formed from the maximum "pressure" of the explosion to the minimum "pressure" of the implosion.
If the flow is closed, the poles disappear and the flow itself forms a ring! The ring is the strongest state of magnetic flux.
rakarskiy
Quote from: Beginners Mind on June 03, 2022, 09:07:08 AM
why would they hide something when the patent is in the public domain. They have Instagram and other platforms.
The problem is different, engineers who can understand and repeat units.
Sincerely
bistander
Ufo,
N & S poles are just labels to help visualize. Unimportant. What is important is the direction of the field, we call B vector.
bi
Beginners Mind
Rakarksky - As you know, the patent does not show an outer rotor.  The patent application was made over 4.5 years ago on Nov 17, 2017.  Improvements have undoubtedly been made in the meantime.  The outer rotor is likely a significant improvement or it would not have been made.  It may be the difference between a marginally effective generator and a highly effective generator.
