Ufopolitics
Quote from: kolbacict on June 04, 2022, 09:10:51 AM
Hmm... Obviously you mean that the car's electrical system will simply turn off the voltage regulator when the engine is not running.
Ignition switch will turn off the supply to all Engine Electrical circuits, and yes, including the Alternator AVR.
Only some of the Accesories (clock) and some of the electronics on board computers will remain on minimal supply power.
Quote from: kolbacict on June 04, 2022, 09:10:51 AMIn our case, the current through the field winding will be determined simply by the ohmic resistance of the winding. I meant it. In the other two cases, I don't know.
I didn't take measurements.
In this case just by using a simple switch, will turn off the supply to exciter coils drivers and so Input to the Mag Field Motor...that is it.
Cheers
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
Ufopolitics
Sorry, I overlooked your statement above...
The current to the Exciter Field is not only determined by the ohmic resistance of its coils.
It is depending on the speed that Rotating Field is driven.
At low speeds, low frequencies currents in the exciter coils will INCREASE.
At high speed currents will DECREASE.
The opposite takes place at Stator Windings...Amperage will Increase with higher operating speeds.
This is the perfect recipe for Overunity...it just have to be adjusted properly.
Cheers
Ufopolitics
―Leonardo da Vinci
Ufopolitics
Well, well, well
And...here we all have the answer about previous debate about AC, 3 Phase "Rotating Field"...As I said before, it don't work, period.
Based on the previous shown failed and abandoned Patent from Molina-Martinez
So, let's review its Abstract:
Abstract
A stationary cylindrical electromagnetic core, made of one piece thin laminations stacked to desired height, having closed slots radially distributed, where two three-phase winding arrangements are placed together in the same slots, one to the center, one to the exterior, for the purpose of creating a rotational electromagnetic field by applying temporarily a three-phase current to one of said windings, and by this means, inducting a voltage on the second one, in such a way that the outgoing energy is a lot greater than the input. A return will feedback the system and the temporary source is then disconnected. The generator will run by itself indefinitely generating a great excess of energy permanently.
So, He was feeding (priming) the Generator Exciter Field with AC Three Phase currents...to create that "Rotational Electromagnetic Field"
And so, it failed to produce, to generate what was expected...or "generator running by itself indefinitely "
Nope, can't do, not with this AC 3 Phase currents, no matter how much "tantrum" is given ...
Cheers
Ufopolitics
―Leonardo da Vinci
rakarskiy
Quote from: pix on June 04, 2022, 07:15:21 AM
The quest for OU in a modified AC motor  :)
Listen, guys have  been doing it with permanent magnets and without permanent magnets, using different winding configuration, exotic windings shapes, switching techniques ect.
You will not get OU from Holcomb, doesn't matter which way you are going to make B field vector rotate.
Wrong patch for OU quest.
Cheers,
Pix
Don't worry, does everything work for Holcomb?
If you correctly calculate the magnetic circuit, the work will be with Over Unity
How do you feel about this organization?   http://klnran.ru
pix
Quote from: Ufopolitics on June 04, 2022, 11:11:58 AM
Well, well, well
Abstract
Cheers
Ufopolitics
.... neither with you,switching the coils a'la Holcomb to get magnetic field rotation.
Just posted it to give a hint how it will end up.
Cheers,
Pix
PS. I did never said that it will OU with 3 phase rotation. Exactly the same- it will not OU with your switching the coils.
