0 Members and 25 Guests are viewing this topic.
pix
Quote from: rakarskiy on June 04, 2022, 11:22:53 AM
Don't worry, does everything work for Holcomb?
If you correctly calculate the magnetic circuit, the work will be with Over Unity
How do you feel about this organization?   http://klnran.ru
Sorry, but I do have only negative feelings about RU.
Nothing good caming trom RU direction.
rakarskiy
Quote from: pix on June 04, 2022, 11:36:56 AM
COMMISSION FOR COMBATING PSEUSION SCIENCE under the Presidium of the Russian Academy of Sciences  / КОМИССИЯ ПО БОРЬБЕ С ЛЖЕНАУКОЙ  при Президиуме Российской академии наук
kolbacict
Quote from: Ufopolitics on June 04, 2022, 11:00:35 AM
At low speeds, low frequencies currents in the exciter coils will INCREASE.
At high speed currents will DECREASE.
The opposite takes place at Stator Windings...Amperage will Increase with higher operating speeds.
This is the perfect recipe for Overunity...it just have to be adjusted properly.
I understand. This is amazing. :)
And if we throw out the coil from the Lundell rotor, and insert a permanent magnet in its place.
What will happen in this case?
Ufopolitics
Quote from: kolbacict on June 04, 2022, 12:53:22 PM
I do not know...ask Pix, He already tried it... ;D
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
bistander
Quote from: Ufopolitics on June 04, 2022, 11:11:58 AM
Well, well, well
And...here we all have the answer about previous debate about AC, 3 Phase "Rotating Field"...As I said before, it don't work, period.
Based on the previous shown failed and abandoned Patent from Molina-Martinez
So, let's review its Abstract:
Abstract
A stationary cylindrical electromagnetic core, made of one piece thin laminations stacked to desired height, having closed slots radially distributed, where two three-phase winding arrangements are placed together in the same slots, one to the center, one to the exterior, for the purpose of creating a rotational electromagnetic field by applying temporarily a three-phase current to one of said windings, and by this means, inducting a voltage on the second one, in such a way that the outgoing energy is a lot greater than the input. A return will feedback the system and the temporary source is then disconnected. The generator will run by itself indefinitely generating a great excess of energy permanently.
So, He was feeding (priming) the Generator Exciter Field with AC Three Phase currents...to create that "Rotational Electromagnetic Field"
And so, it failed to produce, to generate what was expected...or "generator running by itself indefinitely "
Nope, can't do, not with this AC 3 Phase currents, no matter how much "tantrum" is given ...
Cheers
Ufopolitics
We said it produces a RMF, not OU.
bi
