rakarskiy
Quote from: pix on June 09, 2022, 03:35:49 AM
Are you kidding, right?
Please stop trying to convince me that simple machanical machine that utilizes torque leverage has COP>1.
EOT.
Cheers,
Pix
Hello pix!
Absolutely no joke, these are the parameters of a real machine. There are also stone crushers. You, do not be surprised if the air conditioner has an efficiency greater than one.
In addition to the levers, there is a flywheel and an impulse kinematic chain. The effect it works on is called EXOMECHANICAL
https://rakarskiy.livejournal.com/12789.html
Sincerely
SolarLab
Hi rakarskiy,
Sorry but I have completely failed to understand your physics link between HV pulses and the increased energy in the Ruslan Generator type circuit.
For now I'll stick with the hypothesis focused around a pseudo TWT Velocity Modulation - used in Travelling Wave Tube design and can be simulated in CAE. Also, one of the original TWT patents had the HV run along the outside of the helical coil and claimed a power gain. Lots of good theory, applications and development information is available as well.
Will attemp to attach a pdf re: TWT Symposium with some good technical stuff to support my theoretical approach - 12MB so it might not work however.
Regards,
SL
FYI: Go to the last presentation [CST - Monika Balk] for insight into how the Ruslan/TWT integration fits CAE simulation.
rakarskiy
Quote from: SolarLab on June 09, 2022, 03:07:36 PM
Hi rakarskiy,
Hi SolarLab!
I have no accumulated information on technology, only sketches. In a simple variant, if we take the pulse circuit of a single-cycle converter, and apply a resistance of 2-5 kΩ in series with the diode to the primary coil, where the diode shunts the circuit, the electric field of self-induction that occurs will be high. In the secondary circuit, the current will be greater than with a conventional pulse. The reason is the electric field, which stimulates the induction of the secondary circuit from the magnetic field.
I don't know if there is such a technology somewhere, but I tried it. True, he abandoned it, postponing it for the future, switching to working out the resonant circuit of his model.
I met Dorokhov's field illumination, but the device is intended for medical purposes.
Quotehttps://realstrannik.com/forum/attachment/40886
https://realstrannik.com/forum/attachment/40881?download=1
Sincerely!
SolarLab
Quote from: rakarskiy on June 09, 2022, 04:12:20 PM
Hi SolarLab!
Sincerely!
Hi Rakarskiy,
Interesting device but not sure what it's intended application is - medical pain relief... IDK?
Attached an English translated version FWIW.
Not sure we're on the same page however. So, I will "bow out"at this point since it seems
this is really "off-topic" with respect to Holcomb.
Regards,
SL
rakarskiy
Quote from: SolarLab on June 09, 2022, 05:07:26 PM
Hi Rakarskiy,
Regards,
SL
Hello SolarLab!
Probably not on the same wavelength. Everything is simple for me, the circuit engineering approach is secondary, and the processes in the circuit elements are primary. Until I get to the bottom of the primary, the latter is meaningless.
So it is with the stator system of a synchronous generator or a Holcomb static generator. What is the meaning of modeling inaccuracies? These are mistakes, even if they seem to be true.
In the system Kapanadze, Mark et al. are sure that there is electrostatic induction. It is this section in physics that seems to exist, but it is hushed up.
Link to document not solved in "how it works" answer:  http://www.sergey-osetrov.narod.ru/Projects/Boiler/Clever_transformer_from_Zacarinin.pdf
(attached english version)
to one reader who does not calculate what kind of device is in the material, I made the following link:     https://overunity.com/19069/holcomb-energy-systemsbreakthrough-technology-to-the-world/msg567932/#msg567932
Good luck to you, in the ordeals of the search for truth.
