rakarskiy
How difficult it is for you! Take four channels of the oscilloscope: input two channels - current and voltage, output two channels - current and voltage. One impulse can show the whole picture.
For direct current, a voltmeter and an ammeter for input and output are even simpler.
The problem is in the heads and unprofessionalism, and not in the ways to get the measurement result.
SolarLab
HOLCOMB ENERGY SYSTEM - Directly Related Information
For those that might still be interested in studying the Holcomb technology.
Video: How the Holcomb Energy System Works (With No Fuel)
https://www.youtube.com/watch?v=Nm1VJ65LcXM&t=241s
Read the video comments and replies; some are quite interesting, including one regarding
Clemente Figuera's 1908 patent by *dillemburg*.
Being confortable that Holcomb's technology "plays" as advertised, the next phase begins.
Holcomb LinGen Driver Board
When time permits, a proper microprocessor based (STM32 series demo board with display) driver scheme
will be designed (using the same TI Eval Module and Littlefuse SiC's as the bench test setup).
But first lets see if the thing works with the bench test setup.
Since the Holcomb LinGen DRIVER circuits and board are quite technical, the
design will likely be posted at "All About Circuits" and include a parallel Forum
with the details, discussions, and what not. (might also use one of the other typical sites)
Keep an eye out there - should be named something like "Holcomb LinGen Driver."
From their Website: [you're likely familiar with it]
"All About Circuits is one of the world's largest and most active independent
online communities for electrical engineers."
https://www.allaboutcircuits.com/about-us/
Current Bench Test Driver Setup
For the partial bench tests (very brief) a couple of dual channel Juntek JDS-2900 Signal Generators (FG's)
drive TI (Texas Instruments) UCC21530EVM-286 Evaluation Modules (a SiC MOSFET driver board) which
in turn drives the Littlefuse SiC FETs (Silicone Carbide high speed, high voltage) which, in turn, feed the coils.
The JDS-2900 is quite versatile so various input signal combinations can be easily tried. Programmable Logic
Inputs from the Digilent Analog Discovery2 instrument also works well but it's logic level pulses only.
Hope to see you all over at "All About Circuits" for the Driver Test!
SL
rakarskiy
Believe me, in order to understand how the system of Figuere, Holcomb, other patents, even the well-known synchronous mechanical generator, works, you need to understand the method of inducing the emf in the phase circuit. I've been on this since 2018. If everything goes further, the system will be as simple as a designer for a young electrician.
They come to me with questions. Everything is so logical and natural that there are only questions to the modern presentation of these issues of official science.
SolarLab
rakarskiy,
No, I don't believe you!
You will have to coherently write it up and demonstrate exactly how it all works or
simulate it using CAE and present it.
It can't be that hard for you to prove your claims and assertions.
"Believe me's" don't work for me anymore - they never did, actually...
SL
