0 Members and 40 Guests are viewing this topic.
SolarLab
Quote from: rakarskiy on June 11, 2022, 05:03:01 PM
this is exactly what I'm doing, but there is no point in publishing a working prototype yet
Today I discovered that part of my publication is hidden from the reader. I do not believe that someone did it on purpose, but the clarifying details and photos of the layout are hidden.
Great, looking forward to seeing your completed/preliminary work.
Good luck and best regards,
SL
Beginners Mind
Thank you SolarLab.  Would you mind posting the reference for the Holcomb Linear Generator?  I have missed it.  The patents I have studied all discuss geometries with circular "rotors" and stators.  Very much appreciated.
SolarLab
Quote from: Beginners Mind on June 11, 2022, 05:18:43 PM
Work on evaluating the Holcomb concept began around the end of March 2022.
Here are some links [probably missed a few] related to the analysis evolution:
Initial thoughts (applications, etc. 2022-04-05)
https://www.overunityresearch.com/index.php?topic=4261.msg98375#msg98375
Patent link (initial target patent):
https://www.overunityresearch.com/index.php?topic=4261.msg98509#msg98509
Preliminary field roll tests:
https://www.overunityresearch.com/index.php?topic=4261.msg98891#msg98891
https://www.overunityresearch.com/index.php?topic=4261.msg98892#msg98892
Magnetic Field Gain simulation tests:
https://www.overunityresearch.com/index.php?topic=4261.msg98900#msg98900
https://www.overunityresearch.com/index.php?topic=4261.msg98901#msg98901
https://www.overunityresearch.com/index.php?topic=4261.msg98908#msg98908
Flat Solid-State Rotor WO 2018 134233 Holcomb:
https://www.overunityresearch.com/index.php?topic=4261.msg98965#msg98965
Simulation Configuration (various and corrected timing?):
https://www.overunityresearch.com/index.php?topic=4261.msg98977#msg98977
Timing:
https://www.overunityresearch.com/index.php?topic=4261.msg99028#msg99028
Brassboard and CAE results:
https://www.overunityresearch.com/index.php?topic=4261.msg99112#msg99112
https://www.overunityresearch.com/index.php?topic=4261.msg99113#msg99113
https://www.overunityresearch.com/index.php?topic=4261.msg99114#msg99114
Bench Test Driver:
https://www.overunityresearch.com/index.php?topic=4261.msg99201#msg99201
Hope some of these are helpful!
Good Luck and regards,
SL
rakarskiy
Quote from: SolarLab on June 11, 2022, 05:55:11 PM
Timing:
Bench Test Driver:
SL
This is amazing titanic work!!
Trust me, I know what I'm talking about.
But there are a couple of notes.
Firstly, to calculate the design, it is necessary to calculate two power circuits: magnetic and electric, which are connected to each other in the generator, like twin brothers.
(it is necessary to calculate the pulses in the circuits of the generator, idle and full power according to the amplitude connected to the load generator. Calculate the possibility of docking the manifested magnetic field: the excitation circuit and the power circuit. There are two magnetic fields in the magnetic circuit. I have not seen this. Not news for a designer, this is how a synchronous electromechanical generator is calculated. A solid-state generator is no different in this matter. A rotating magnetic field!)
Secondly: the electronic control circuit, without taking into account the change in the inductance of the electromagnet coil, at the moment of the impulse, is very likely to be erroneous. If you do not know exactly how changes work in the dynamics, a magnetic circuit, an electric circuit, in their complex configuration, it is reckless to set control tasks, in my opinion. The control system must be possible, both on analog elements and with digital programming.
Sorry for such a short lesson, but first you had to get acquainted with the discipline, the design of electrical generators. When you get deeper you will find it. such an element that will be incomprehensible to you in space, how is the EMF induced in the wire. I am still open this question. I see the mechanism but do not find its explanation in physics. They skip this moment, and that's all here according to such initial output parameters.
Good luck to you!
I won't interfere and object anymore, I always follow the rule "every seeker has the right to his own rake"
I moved my publication drawing and photo hopefully will be available.
http://rakarskiy.narod.ru/publ/free_energy_systems/ssg_ukraine/3-1-0-98
