0 Members and 18 Guests are viewing this topic.
bistander
Quote from: SolarLab on June 14, 2022, 01:11:08 AM
2 months ago (edited)
All generators operate by taking advantage of this alignment mechanism. However, the standard generator
rotor only aligns the domains one time at start-up, and then gets no further energy advantage from the
aligning process. In comparison, the HES aligns the domains and relaxes the alignment, and re-aligns
and relaxes continuously every 4 milliseconds. Therefore we get the magnification effect 250 times per second
SL
Hi SL,
All AC generators align (realign) the magnetic domains in the majority of the field magnetic circuit at electrical frequency. That's why they use electrical grade steel (having low hysteresis loss).
If one desires to have both the stator and rotor develop a rotating magnetic field (RMF) independently from each other, and independent of mechanical speed, look at Doubly Fed Induction Machines.
bi
rakarskiy
Pointing this out again - since it's important to understanding yet another significant difference!
This is also quite evident when examining the CAE simulations.
https://www.youtube.com/watch?v=Nm1VJ65LcXM&t=7s
One comment by "tgdyt2" and the "Holcomb" reply:
tgdyt2
2 months ago
Apparently in all your study of physics you never stumbled across this:
https://en.wikipedia.org/wiki/Conservation_of_energy
You can't create energy out of nothing. Something must be consumed/transformed. Electron "spin" itself
does not possess energy, and it if did, you would be taking it away, thus changing it, which could not be
perpetual.  E=mc²  Are you transforming matter into energy?  You can't do that forever either.
Hey rakarskiy - good to see you're starting to figure it out, that's great! Looking forward to your book.
SL
Hello SolarLab!
The Law of Conservation of Energy does not work in any way in a solid state generator system. In reality, there still need to limit the input power.
Magnetism and electricity, in no way can be tied to physical mass and physical speed. Above, I gave two power formulas - mechanical and electrical.
This is the paradox of the device, a synchronous mechanical or solid-state generator. In terms of input of electrical excitation power and output of useful amplified power to the consumer, mechanical and solid-state generators are almost identical. We excite with less power, we get more. The amplifier is the ability of the "magnetic flux" to accelerate - in the electrical steel material.
For example, if the magnetic "conductivity" of the magnetic flow of air is 1, then the magnetic "conductivity" of electrical steel is up to 4000.
What's this? This is superconductivity relative to the conductivity of air in a vacuum. Correctly called magnetic permeability. But this is the initial parameter, then there is magnetic saturation. With a drop in magnetic permeability and an increase in magnetic intensity, the conductivity decreases and the calculation of magnetic saturation (magnetic induction). Magnetic induction has a limit to this saturation, so pushing in more to get more will not work.
This is a good couple of chapters. Although everything is in the academic textbooks of physics. This is not a closed science, it is taught in all specialized educational institutions.
Sincerely.
r2fpl
There is no need to rotate the magnetic field! It doesn't do anything.
The only reason for this construction is the use of magnets or the desire to create a pure sine wave.
SolarLab
Hey Fellows, relax... take a Valium or have a beer...
Take it up with the Inventor, the Simulation results or the preliminary bench tests.
Have you all done any of these? (My bet is NO! Blowing smoke and real work are different.)
Regards,
SL
bistander
Hi all,
From the start, I thought this HES concept was nothing more than a common 3-phase dynamo at stall, including the instant of starting induction motors across the mains just prior to rotation commencing, and even during locked rotor test and overload stalls. These situations have been studied and modelled for years by experts. To my knowledge there has never been a reported overunity or anomalous energy occurrence. The majority of such machines are cage rotor types. But the doubly fed Induction Machines, as used for wind turbines, and slip ring induction motors have access to rotor power directly. So here's my question to anybody. How is HES different from a slip ring induction motor at stall?
Attached is a snapshot showing the device. The rotor can be locked and starting resistors considered the load. Therefore the 3-phase mains provide a RMF thru the stator inducing the stationary rotor and its windings which delivers power to the load while nothing moves (no copper or steel, just magnetic field and electric charge.
Thanks.
bi
https://engineeringslab.com/tutorial_electrical/starting-of-slip-ring-induction-motors-797.htm
