0 Members and 82 Guests are viewing this topic.
SolarLab
Quote from: sm0ky2 on June 18, 2022, 01:17:11 AM
Its not an energy or power gain.
The original patent only steps the voltage, not the current.
Current is lowered, resulting in slightly less total power out than in.
And your proof or analysis is?  Some varification is always helpful.
Thanks - appreciated....
SL
kolbacict
https://overunity.com/19069/holcomb-energy-systemsbreakthrough-technology-to-the-world/dlattach/attach/187576/
Фигня какая то нездоровая.
What does this patent say?
There is nothing even round, everything is rectangular. :o
bistander
Quote from: SolarLab on June 18, 2022, 01:02:40 AM
Read the examples then think about it a bit more.
Shipping (a live device - a definite no no). Storage, again a no no.
Maintenance - troubleshoot or fix a "hot device" - not me. Initialization - on and on?
Ideas are welcome, not stupid, out of the ass stuff...
SL
SL,
It's intended to be always on when in service, isn't it?
Also, using some creativity could overcome your objections. How dangerous is it to work on a live device of that power level? Or seal it so it cannot be serviced; must be disposed/recycled.
Or if you insist, package it in a box, that has a lid, which, when opened, activates a small dynamo that generates a pulse to initiate the device startup. It could be spring loaded storing initial energy, or not, requiring the act of opening to supply the initial energy. Let the flip of the flip-phone do it.
bi
Cadman
Quote from: SolarLab on June 17, 2022, 11:07:53 PM
Should clarify a bit more - the controller/driver card is a pcb that runs along the clean ends
(no windings are in the way) of the rotor-stator plates. Dimensions of the two plates are
approximately 3.2" [+ pcb-SM] x 5.2" x 1" plus coil overun. These units can be stacked or linear,
as required.
The top and bottom of the rotor-stator plates are flat and clear (hint - capacitor/inductor/electrostatic???).
{unroll an electrolytic - back emf - etc. still thinking...}
Ah, I was imagining the big generator pictured on his site.
How about something like a shaker flashlight generator with a cap pulse discharge. That could even be a separate plug-in device with multiple uses.
The cap pulse part could be built into the linGen with a start button, chargeable by various means.
SolarLab
Quote from: Cadman on June 18, 2022, 08:00:47 AM
Cadman,
Bingo!  Sharp thinking, thanks. A Shaker Flashlight concept.
Notice the Lap/Coil/Windings stick out of the Pole Plate sides - wind them into a helix, plastic tube core,
strong magnets inside (with keepers so they only move when required).
Release keepers and SHAKE until the Start Capacitor (SuperCap or layers on the stator plate) is
charged (check LCD Display for "READY TO START"). Device can be held in a hand.
Push the "START" button and walla!
Will simulate this scheme and determine the winding, magnet and capacitor characteristics.
Thanks again - quite smart and in record time...
SL
- a seperate device (module) with multiple uses is also very attractive. Easier to build as well.
   (batteries sold seperately -  :( ) That way the LinGen will still fit in my self propelled electric lawn mower   ;) !
You've probably guessed where I'm going with this. Good to have a target application when you start a design.
At $100+US for <45min run time (big yard). Thats about 4X$100 every couple of years; plus a trip to Hazardous Waste.
