Beginners Mind
Newcomers - There is also some convincing data shown in several graphs of self-running generators in the Figures of the 2021 international patent application, https://patents.google.com/patent/WO2021063522A1/en?oq=WO2021063522.  These self-running graphs are presented both with and without the HES voltage & phase stabilizing "oscillating module" described in the patent application.  This patent application references rotor-double stator-rotor and stator-double rotor-double stator-rotor configurations.  It does not directly address the LinGen that SolarLab is working on to demonstrate the proof of concept behind these larger, cylindrical HES generators.  The LinGen or flat configuration is described in the patent application SolarLab posted above.
Holcomb Energy Systems patents/patent applications present several embodiments of their technology, which can be confusing at first.  They are:
rotor - stator (original configuration)
rotor - double stator -rotor
stator - double rotor - double stator - rotor
flat rotor - stator ("LinGen")
In each embodiment a moving magnetic field is produced by sequentially pulsing DC coils.  Coils at the leading edge of the field are energized at the same time those at the trailing edge are relaxed.  As the cycle repeats the polarity of the magnetic field is reversed.  This is true also in the flat rotor patent application.  If you study the patents you will see the coils of all embodiments are powered via H-bridge type circuits which pulse positive, neutral, negative, neutral, positive...  They variously describe both a 50% and 75% duty cycle of the pulsed coils with 50% the most referenced embodiment.  But in each case the coils receive a pulse, relaxation, reversed polarity pulse, relaxation, etc.
HES's first commercial product is to be called the In Line Power Generator ("ILPG") which they state has a stator - stator configuration.  Regardless of the terminology this configuration also creates a solid state rotating magnetic field.  The ILPG, including rotating magnetic filed and over unity operation, is demonstrated on their Instagram home page by clicking the "Tech" icon video clip in the upper left.
Beginners Mind
NEWS FLASH DIRECTLY FROM HOLCOMB!
Immediately after making my above post describing the pulsed coils referenced in the HES patents and patent applications, I checked the HES Instagram page and found the following game-changing reply to a question I posted to them.
My question to HES about their In Line Power Generator (ILPG):  "Does the ILPG convert the AC input to a sequence of DC pulses which creates a rotating magnetic field in electrical steel like your self-running generators? Or does the AC input create the rotating magnetic field without being converted to DC first?"
HES's reply:  "That refers to ur old patents. currently both the ILPG and self sustaining unit only use AC. "
The ramifications of this are tremendous!  It now makes much more sense why they call their ILPG configuration a stator - stator.  Is it possible the rotating magnetic field created by one of the stators is generated somewhat like the AC-created rotating magnetic field in the stator of a slip ring induction motor?
Understanding the latest Holcomb tech now boils down to understanding how they wired both "stators."  WAY simpler than all that sequentially pulsed DC!
But more importantly:  WHY does what they do work?  What has Dr. Holcomb done in his stator - stator wiring configuration to mitigate Lenz's law?  That is what puzzles me the most.  There is no doubt that HES has created a series of over unity devices to anyone who has taken the time to study all their patents, patent applications, web site, YouTube videos and Instagram posts.  Naysayers please take the time to do thorough research on HES before saying it can't be done.  It has been done.  The really interesting question is what is Dr. Holcomb doing that gets around Lenz's law enough to make his tech work?  The electrical steel amplification pitch is simply a way to make a lay audience and patent examiners comfortable with how over unity could be possible.  The real trick is in sidestepping the full brunt of Lenz's law.  Dr. Holcomb unquestionably realizes this.
bistander
Quote from: Beginners Mind on June 20, 2022, 04:09:17 PM
That's interesting.
bi
SolarLab
Beginners Mind,
Some very good information - thanks.
FWIW - while looking at some simulations it appeared to me that the operation was like a
"Snowball Game" - yea, I know sounds pretty dumb - but just trying to verbalize the interaction.
Here are the two posts where I wrote it up:
https://www.overunityresearch.com/index.php?topic=4261.msg98737#msg98737
at the bottom, and what I called the "Snowball Game" here:
https://www.overunityresearch.com/index.php?topic=4261.msg98746#msg98746
Corny analogy; but it's hard to describe in words without seeing the animations.
There are a variety of other things that also contribute to excess energy in the HES - some
of these have been pointed out over the many posts.
SL
Beginners Mind
SolarLab,
Thanks for the links.  Your hypotheses make a lot of sense when based on DC pulses and are very much like what I expected might be happening in all the original patent applications.  But if HES has now dispensed with DC pulses entirely and is currently operating completely on AC to create the RMF, do these ideas still apply?  AC does not throw discrete snowballs like DC pulses do.  Is another hypothesis needed?  What do you think?  Dispensing with sequential DC pulses makes the workings of this tech ever more fascinating.
