0 Members and 79 Guests are viewing this topic.
rakarskiy
Quote from: Lunkster on June 21, 2022, 11:07:18 AM
Another question:
Can this technology be put into power assist bicycles and other products
that will multiply the range of those products?  I know that a COP over 1 will
give a product with infinite range, but I still need to get my exercise.
Do the current Patents protect HES from other FE generators to compete with them
in the area of power generation with COP greater than 1.
Lunkster
How can a patent protect the principle of power generation? There is another patent that can be challenged, also indicated in this thread.
Or electromagnetic induction, discovered by Michael Faraday, is not used in the Holcomb generator.
Why, then, do not all design bureaus and generator manufacturers in the world ask permission from Faraday?
Manufacturers may cooperate with Dr. Holcomb, in terms of technical documentation of generators, on permits that Holcomb can obtain.
How many episodes do you know with permission to produce and exploit?
The problem is not in the method, but in its development by manufacturers and operating companies.
pix
Quote from: Beginners Mind on June 20, 2022, 04:09:17 PM
NEWS FLASH DIRECTLY FROM HOLCOMB!
Immediately after making my above post describing the pulsed coils referenced in the HES patents and patent applications, I checked the HES Instagram page and found the following game-changing reply to a question I posted to them.
My question to HES about their In Line Power Generator (ILPG):  "Does the ILPG convert the AC input to a sequence of DC pulses which creates a rotating magnetic field in electrical steel like your self-running generators? Or does the AC input create the rotating magnetic field without being converted to DC first?"
HES's reply:  "That refers to ur old patents. currently both the ILPG and self sustaining unit only use AC. "
The ramifications of this are tremendous!  It now makes much more sense why they call their ILPG configuration a stator - stator.  Is it possible the rotating magnetic field created by one of the stators is generated somewhat like the AC-created rotating magnetic field in the stator of a slip ring induction motor?
Understanding the latest Holcomb tech now boils down to understanding how they wired both "stators."  WAY simpler than all that sequentially pulsed DC!
I told you guys  ;D ;D ;D
3 phase balanced signal into locked rotor of slip ring motor.
Next lesson: don't expect any OU from this anyway.
Cheers,
Pix
PS.
Pssst. Don't tell this to Ufopolitics and rakarskiy ;)
pmgr
Well, at least the discussion between UfoPolitics and Bistander regarding using switched DC or AC to generate a rotating magnetic field should be resolved. Both work. :)
rakarskiy
Don't bother, the three-phase motor stacking system is not designed to focus flow. Perhaps multipolar, but there are many - but. If you want a solid state generator, study the subject of how a generator works. The motor does not work with flow focusing, the motor works with area. When you understand the difference between the rotating field of a motor and the rotating field of a generator stator, you will understand how far these fields are from each other.
Two formulas: E=BLV;  E =4.44wfBS,  when you get the same EMF value, you will understand everything yourself.
In the meantime, in a simple experience, the result of the transformation, the Over Unity is confirmed.
https://overunity.com/19069/holcomb-energy-systemsbreakthrough-technology-to-the-world/msg568178/#msg568178
