0 Members and 63 Guests are viewing this topic.
pix
Quote from: rakarskiy on June 21, 2022, 02:56:55 PM
Don't bother, the three-phase motor stacking system is not designed to focus flow. Perhaps multipolar, but there are many - but. If you want a solid state generator, study the subject of how a generator works. The motor does not work with flow focusing, the motor works with area. When you understand the difference between the rotating field of a motor and the rotating field of a generator stator, you will understand how far these fields are from each other.
Two formulas: E=BLV;  E =4.44wfBS,  when you get the same EMF value, you will understand everything yourself.
In the meantime, in a simple experience, the result of the transformation, the Over Unity is confirmed.
https://overunity.com/19069/holcomb-energy-systemsbreakthrough-technology-to-the-world/msg568178/#msg568178
OU confirmed same way like in your mechanical press? ;D
Spare me.
Cheers,
Pix
pix
Quote from: pmgr on June 21, 2022, 02:05:54 PM
Well, at least the discussion between UfoPolitics and Bistander regarding using switched DC or AC to generate a rotating magnetic field should be resolved. Both work. :)
Correction.
Both do not work to produce any OU.
Cheers,
Pix
pix
Quote from: matu on June 21, 2022, 02:11:40 PM
Hello, virtual rotating field tests in an alternator rescued from the scrap.
https://www.youtube.com/watch?v=nOeSpIqu98c&t=16s
https://www.youtube.com/watch?v=Sdl2mIcSSow&t=480s
Cheers
I already quoted Molina Martinez patent on this thread. No OU there.
On the first video you see kind of slip ring AC motor,  3 phase stator and a rotor with only 2 slip rings, dude connects 3 phase inverter to the stator  creating rotating maghetic field and takes power from slip rings of the rotor. Don't understand spanish but you can see on the multimeter and power consumption meter that there is no OU. Not sure how big is air gap between rotor and stator but definitely they are coming from different machines.
Even if you will use original 3 phase AC slip ring motor, and power it via 3 phase inverter to 3 slop rings and take power from stator coils- it will be like 3 phase transformer, no OU there.
Holcomb claims are a bust.
Cheers,
Pix
alan
Jimboot
Quote from: rakarskiy on June 21, 2022, 01:12:04 AM
If you are going to conduct an experiment, connect the rotor circuit through LATR, connect the load. Next, you need to find the position of the rotor at which the process will have a working moment. Moving even half of the surface of a part of a stator tooth can be critical for a two-pole rotor.
Good luck.
Used a 24VAC power supply for initial test. Wired 2 rotor poles in series 16ohm, my load was a 15 watt incandescent lamp. I could barely get 2 volts from the stator coils. More testing tonight. Maybe the rotor coils should be in series with the lamp but not each other to drop resistance back to 8ohm.
