0 Members and 64 Guests are viewing this topic.
Beginners Mind
Interesting efficiency data just published by Holcomb Energy System is in the .pdf file attached.  This relates to their In Line Power Generator (ILPG) which has an efficiency of about 200% and is to be their first commercial product.  HES is billing the ILPG as a device to be wired between the mains input to a facility and the facility's loads in order to halve the electric bill.  HES is specifically not drawing attention to the fact that the ILPG could be looped back into itself, disconnected from the grid and function as a self-running generator.  Data on self-running embodiments of their tech is present in their WO2021063522A1 patent application.
rakarskiy
Quote from: Jimboot on June 21, 2022, 08:46:46 PM
Used a 24VAC power supply for initial test. Wired 2 rotor poles in series 16ohm, my load was a 15 watt incandescent lamp. I could barely get 2 volts from the stator coils. More testing tonight. Maybe the rotor coils should be in series with the lamp but not each other to drop resistance back to 8ohm.
Find the optimal position of the rotor in the stator. This is not a simple process, you need to turn the rotor by one stator tooth, each time and try, you need to find the position at which the induction is maximum.
For your drive in this matter:
https://youtube.com/shorts/0LmQzSx06uE
For all who doubt, doubt your health! Take care of your nervous system!
For alternating current: input and output - the wattmeter showed everything correctly, according to its technical characteristics. It is enough to evaluate the result
r2fpl
Again, measurements with devices that do not show correctly when measuring disturbed current.
alan
Quote from: Beginners Mind on June 21, 2022, 10:07:12 PM
If the flux doesn't change by growing and diminishing because coils are pulsed, then efficiency is higher, Lenz works against this change (unless change in s and n cancel in the HES). Changing flux through the area of a conductor causes induction and the change is countered by Lenz when amps flow, motional E also moves and separate charges and induce an EMF, but it can't be countered because the EMF and amps are not caused by the changing flux through an area, but by a time varying magnetic vector potential in space, this creates an E-field, the time-varying MVP is created by rotating a curled magnetic vector potential by the magnetic poles, while trying to keep flux-change through the area of the coil zero. Lenz appears, but according to the right-hand rule, it works against nothing. Cmiiw
pix
Quote from: alan on June 21, 2022, 08:14:38 PM
Is OU possible at all?
I will give you an example.
A common room air conditioner or a heat pump. Typical COP=3, that means you put IN 1 kW of electrical power and get OUT 3 kW of power in the form of heat.
Is it OU?
No. It is just a thermodynamic pump that taps to ambient heat existing in the atmospheric air. It compresses large amount of cubic meters of ambient air with low grade temperature, let's say 10 degC to smaller amount of cubic meters of air at let's say 40 degC that is useable to heat your home in the winter.
Source of energy is known- ambient air.
Energy may be converted from one form to another, or from "low grade form, not useable" to "high grade, useable".
Do solar panel is OU? No, it produces electricity from "free" solar radiation. We tapped to that source of energy and converted it to electricity.
There is a lot of such "free, low grade forms" of energy around us. We just need to be smart to create CONVERTERS that can turn non useable form of energy into useable.
The same way we could utilise magnetic field of permanent magnet in the flyback mode MEG.
Regarding Holcomb claims, I do not see a "energy source" that could lead to COP>1. Spinning magnetic field across AC motor stator makes it an ordinary generator, the only difference is there is no mechanical rotation  to create rotation of magnetic field. Lenz law apply.
Cheers,
Pix
