0 Members and 42 Guests are viewing this topic.
                                                        -1                  0              1
                                                    BEMF                                 EMF
                    theme                                     Power Factor                         mono-phase circuit / tri phase circuit / poly phase circuit
                               https://www.fluke.com/en-us/learn/blog/power-quality/power-factor-formula
        Feedback !?
                                               net-grid cycle        /         battery-source cycle
                                         max 50% potential     /        max. 100% potential
                                           industry process to private household battery -source process
                                         industrial net-grid displacement current compensation process !?
https://www.google.com/search?q=industrial+electric+displacement+current+compensation+process&client=firefox-b-d&sxsrf=APq-WBvU8ysE41AI1UpBgOJSTklpl51qtQ%3A1648069829920&ei=xYw7YvjrN8vykwW41aLYCQ&ved=0ahUKEwi44pvGkt32AhVL-aQKHbiqCJsQ4dUDCA0&oq=industrial+electric+displacement+current+compensation+process&gs_lcp=Cgdnd3Mtd2l6EAw6BwgjELACECc6BAghEApKBAhBGAFKBAhGGABQ4w1YsSBguTNoAXAAeACAAYMBiAG3B5IBAzQuNZgBAKABAcABAQ&sclient=gws-wiz
Ufopolitics
Quote from: bistander on March 23, 2022, 04:35:25 PM
Hi Ufo,
An induction motor (say a 3-phase, 60 Hz 2-pole machine) will operate as a generator quite well if driven above 3600 RPM. This is well known and often used. There is no DC feed and no diodes or commutator or other means to convert AC to DC.
Thanks to Tesla (the guy, not car co.), we know a method in which the 3- phase stator windings are placed such that when excited by a sinusoidal 3-phase alternating current produces a constant magnitude (and polarity) flux wave which travels (rotates) around the air gap at synchronous speed (line frequency/pole pairs).
bi
ps.
Look it up. I think it can be found in all EE textbooks, at least all I've seen, which is more than a few.
Hi Bistander,
As you've written "it could be used"...
Plus have to be a "Two Pole Rotor"...why?
In order that those two Poles eventually magnetize as a N-S...right?
I also know that, however, it is not how a conventional Three Phase Generator works.
Otherwise I could also cite here that I can use a permanent magnet motor as a generator ..lol
And yes I know stator windings are also spaced at 120° apart, just like in a 3 phase generator...
You very well know, that in Conventional Power Generation Systems, the Exciter Coils are converted into DC to give a constant magnetic field polarization.
Anyways, point here was about my view on these Patents, not about "another class" about magnetic induction...
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
                        Geben WIR dem gesuchtem Kinde den Namen :
                                            AC CONDUCTION motor
         or                               AC CONDUCTION CURRENT motor
         =                               AC    DISPLACEMENT CURRENT motor
         or                              AC    BLIND CURRENT                   motor
         or                              AC    WATT-FREE                          motor
                       https://www.quantumstudy.com/physics/electromagnetic-waves-2/
                                        q.e.e.         quod  erat explanandum
       btw :                                   1 Hz = 2 pulses or 2 signals
       the controle tool called                  Pulse With Modulation  ,shortly MODULATOR,by Laplace theorem " Operator"
        AM  Amplitude Modulation
        FM  Frequency Modulation
        ? M         ?          Modulation    ? = DUTY  ::) dis-/continuum  ;)
      more : https://www.google.com/search?client=firefox-b-d&q=kanarev+pulse+power
bistander
Quote from: Ufopolitics on March 23, 2022, 05:04:55 PM
Hi Bistander,
Ufopolitics
Ufo,
No. I was speaking about squirrel cage induction motors like what are most commonly used. So the number of rotor poles is the same as the stator pole count. And the generator operation is valid for  4-pole, 6-pole or any # of poles machine. The synchronous speed will vary with pole count. I just used 2-pole, 60Hz and 3600 RPM as an example to keep it short. Please look it up.
bi
#83 : https://en.wikipedia.org/wiki/AC_motor
  • 3 Induction motor
    • 3.1 Slip
    • 3.2 Polyphase cage rotor
    • 3.3 Polyphase wound rotor
    • 3.4 Two-phase servo motor
    • 3.5 Single-phase induction motor
      • 3.5.1 Shaded-pole motor
      • 3.5.2 Split-phase motor
        • 3.5.2.1 Capacitor start motor
        • 3.5.2.2 Resistance start motor
        • 3.5.2.3 Permanent-split capacitor motor
  • 4 Synchronous motor
    • 4.1 Polyphase synchronous motor
    • 4.2 Single-phase synchronous motor
    • 4.3 Hysteresis synchronous motor
  • 5 Other AC motor types
    • 5.1 Universal motor and series wound motor
    • 5.2 Repulsion motor
    • 5.3 Exterior rotor
    • 5.4 Sliding rotor motor
    • 5.5 Electronically commutated motor
    • 5.6 Watthour-meter motor
    • 5.7 Slow-speed synchronous timing motor
