0 Members and 65 Guests are viewing this topic.
pix
Quote from: rakarskiy on June 22, 2022, 07:07:54 AM
Do not be upset, understanding will come, read again and think!
https://rakatskiy.blogspot.com/2022/06/magnetization-of-steel-magnetic.html
PS: 1 kW = 1000 J, 3 kW = 3 J. 1<3 no matter what form it goes into, it is more than one, everything else .....
According to rakarskiy every room air conditioner is an OVERUNITY device  ;D
Along with his  mechanical press  ;D
Well. Gentelmens!
Mr. rakarsiy already found a Holy Grail OU , this forum is no more needed  ;D
Cheers,
Pix
alan
Quote from: pix on June 22, 2022, 07:31:19 AM
Well. Gentelmens!
Cheers,
Pix
it is, usable but not marketable.
EM-'OU' is pumping energy from the vacuum instead of putting in energy to get an equal out of the vacuum.
OU doesn't exist, EM COP>1 is the goal.
1kW=1000 J/sec. Watt = average energy per second.
rakarskiy
Quote from: alan on June 22, 2022, 07:37:43 AM
The SI system has a base unit of time of 1 second.
Therefore, 1 J = 1 Watt / second or 1 Joule / second = 1 Watt are identical, therefore 1 J = 1 W is absolutely correct. Everything else is a puff of the cheeks or an indicator of the absence of a higher school in the luggage.
Sincerely!
PS
don't forget that pandora's box is open
https://youtube.com/shorts/0LmQzSx06uE
bistander
Quote from: rakarskiy on June 22, 2022, 08:28:36 AM
Sincerely!
How can you say "1 J = 1 Watt / second"?
Correct is:
1 J = 1 watt second
J = Joule, a unit of energy or work
W = Watt, a unit of power, defined as the rate at which work is done or rate at which energy is transfered or converted, therefore Power in watts = Joules / second, 1 W = J / s. Math tells us that:
1 J = 1 W • s
Not as you say!
bi
