0 Members and 25 Guests are viewing this topic.
Jimboot
Quote from: rakarskiy on June 22, 2022, 01:52:09 AM
Find the optimal position of the rotor in the stator. This is not a simple process, you need to turn the rotor by one stator tooth, each time and try, you need to find the position at which the induction is maximum.
For your drive in this matter:
https://youtube.com/shorts/0LmQzSx06uE
For all who doubt, doubt your health! Take care of your nervous system!
For alternating current: input and output - the wattmeter showed everything correctly, according to its technical characteristics. It is enough to evaluate the result
Looks like I'm using the same gen. Looks like he has all the output phases wired. I didn't. Bit hard to tell what is going where. Will check again tonight
rakarskiy
Quote from: Jimboot on June 22, 2022, 10:24:27 PM
The result obtained on the excitation winding (the one with 8 ohm resistance) - the scheme of the experiment
PS
don't forget that pandora's box is open
Jimboot
Thank you sir. So the 8ohm was referring to the stator and not the rotor coils in series. I appreciate the schematic. Will report back.
Frederik2k1
Quote from: rakarskiy on June 23, 2022, 01:28:28 AM
PS
How is this possible? Can you trust the meters?
I wonder if this is the scheme from Xiaodong Liu et. al.: A novel Transformer with compensation coil, which states:
QuoteThe power can be delivered with zero input current in the primary coil when the turn number of secondary
coil is the same as that of compensating coil. When a boost coil is added to the
compensating coil, the input current in primary coil is phase inverted relative to its input
voltage. A magnetic shunt is added to adjust the flux leakage of this transformer.
See attached PDF, posted in https://overunity.com/18878/reactive-current-parallel-rcl/345/ .
kolbacict
