kolbacict
https://www.youtube.com/watch?v=6L-ar3g4Kls
Can anyone tell me what it is, after all?
This is not about Holcomb, but still very interesting.
Это чё,работает ?!!
p.s.
And about the work of this selsyn, I wanted to add.
https://overunity.com/19069/holcomb-energy-systemsbreakthrough-technology-to-the-world/dlattach/attach/187562/
That if the rotor is released and allowed to rotate freely, then the power on the rotor brushes is greatly reduced.
And vice versa, if the rotor is forced to rotate by another engine
in the opposite direction, power is added.
alan
Here the mechanical version of the holcomb/dz gen:
https://www.youtube.com/watch?v=HwZXhUZyroA
The number of flux lines through the surface area of the coil doesn't change.
Jimboot
Quote from: rakarskiy on June 23, 2022, 09:22:34 AM
open-circuit voltage indicators of the original experiment. input to the rotor winding 210V, output from the excitation winding 117V.
I have not measured current but it's not that high. Wiring the rotor coils in parallel results in 26v on the output but I cannot blow a 12v 1amp lamp and can only glow a 240v incandescent house globe dimly.
rakarskiy
Quote from: Jimboot on June 25, 2022, 07:42:16 PM
What voltage is the rotor winding of your generator set (rotor-stator) rated for? Have you also found the most optimal position of the rotor in the stator?
I have indicated everything that was done in the experiment. The guy at the exit had a water heater P - 0.7 kW (220V * 3.18A, at P - 69 Ohm).
No-load EMF at the output 117V, voltage with heating on 39V. Phase resistance 8 ohms. This is the data from the video he sent me. Understand the rotor winding, what is the maximum voltage applied to its terminals.
The guy on the video launched the heating element at only 20% (140W) of its capabilities (700W). This is approximately 1.2A.
PS: You have too few values for real analysis, input power and output power are difficult to determine
rakarskiy
I think  need to be creative with any subject.
QuoteA locksmith monkey will only turn into a locksmith monkey. To make a locksmith, at least a person must be a person with the motivation to be a locksmith. Labor is different: creative, compulsory and forced. Only creativity makes a person free
