0 Members and 67 Guests are viewing this topic.
kolbacict
Quote from: rakarskiy on June 29, 2022, 08:42:17 AM
You can try a likefuck from me.
Maybe lifehack ? :D
QuoteTake very small metal shavings and pva glue, make a thick mixture and fill the gap between the rotor and the stator. Back in 1982-83, we did this to increase the flux linkage of electric motors.
And how did they rotate after that?
rakarskiy
Quote from: kolbacict on June 30, 2022, 04:40:03 AM
Maybe lifehack ? :DAnd how did they rotate after that?
They rotated perfectly with clearly better performance than with the traditional clearance, it was just that during the solidification period it was necessary to turn the anchor slowly in the stator. Here, in the process of work, heating destroyed PVA. Not immediately, but gradually. If you apply a base that is more resistant to heat (in our 21st century this is not a problem), the operation of the electric motor will work for a long time with such an improvement.
Jimboot
I need new DMMs again I think. I need a better way to measure this, something physical. My readings with a new cap are so ludicrous I need to set up my Rigol 4 channel scope to do the math for Pin Pout maybe but even then I won't be convinced. I call BS on myself before anyone else does. Quite frankly I need to try and debunk what I'm seeing. My input is 15 watts. That's seems reasonable but my output is not. It's quite unreasonable but my lamp is brighter than before and the transformer is noisier so there appears to be a net gain. But until I have a physical experiment that can demonstrate the difference clearly I will not accept what my DMM is showing. I have not worked much with AC so I need to better understand what is going on here. Any suggestions for physical experiments not involving meters are welcomed. I am now able to dimly light this halogen
kolbacict
Quote from: Jimboot on June 30, 2022, 08:05:43 AM
Make a self-running.
QuoteThey rotated perfectly with clearly better performance than with the traditional clearance, it was just that during the solidification period it was necessary to turn the anchor slowly in the stator.
At first I thought you were gluing the rotor to the stator.
Ufopolitics
[...] Any suggestions for physical experiments not involving meters are welcomed. I am now able to dimly light this halogen
Hello Jim,
Have you tried to read/see/measure output sinewave on a simple two channel scope versus Input signal?
This simple readout, I consider it is very important to see what is the shape and height (strength) of your output signal versus input.
Since you have AC on both sides it would be easier to compare if both probes are set exactly at same sensitivity scale.
Further on, I would recommend a Current Probe (like Tektronix A622 or A621) which you could connect to one of your scope channels.
And you have a 4 Channel Scope (I wish I had one, but they are too expensive!!) which -(as I consider it)to be the top of the tools to measure everything at once, in just one screen!!
With 4 Channels, and two current probes, plus the other two typical probes, you could measure Input V/A as Output V/A in one screen!!
These Current Probes convert in scale on Scope, Millivolts to Amps (10 mV/A-100mV/A) so you could see your amp peak on the screen.
Ufopolitics
P.D: If you are willing to, I can invite you to open your own Moderated Topic/Thread under my main thread which is based on the same principle...Moving the Magnetic Field(s) to generate Energy.
There you could align all your files, pictures and videos as any explanations in order, not scattered all over.
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
