Jimboot
Getting phase cancelation trying to run the stator coils in parallel. Also just dimly lit a 30watt fl which was weird. The power out is directly related to the load. Ie my 12v 1amp lamp will not blow. Under load it measures 25vac but only 600ma
rakarskiy
Quote from: Jimboot on July 02, 2022, 02:17:12 AM
Check again. Possible switching error or very fast saturation to the maximum. EMF and current only when the curve goes up or down.
Ufopolitics
Hey Jim,
If you are getting canceled out in parallel it is because you have end-start in one point out, and end-start on second point out, so they will cancel.
Each coil or circuit of series coils always have a Start and an End terminal.
For Parallel output, it must be start with start and End with End.
So, try reversing just one of the two circuits terminals (Exciter or Main Out) and reconnect.
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
rakarskiy
Jimboot , a series connection is one winding resistance as a load. Parallel connection is a reduced winding resistance as a load. Take simply measure the resistance of the windings in series and parallel, and calculate the current according to Ohm's Law. You may find an error.
