0 Members and 64 Guests are viewing this topic.
rakarskiy
Another interesting patent!
"Motor generator and other transformer" - 1935-11-19  Publication of US2021177A
https://patents.google.com/patent/US2021177?oq=US2021177
QuoteThe rotor ll of the motor-generator is shown in figures I and II and is provided with four poles I6. Rotor me! mounted on a shaft l 8 and can rotate with this shaft. A pair of insulated slip rings l3 and another pair of insulated slip rings I4 are also mounted on shaft l8 and rotate with this shaft. The slip rings M are rotatably connected at point b with the pole winding 1 of the rotor II. In the modification shown in the drawings, the pole windings I of the rotor II are connected in parallel with the primary windings 6 of the stator. Obviously, the windings 6 and I can be connected to different energy sources or connected to each other in series or jointly.
DC power supply 22, shown schematically in FIG. I, is connected by conductors to a pair of fixed brushes l5, which are pressed against two rotating current collector rings 14. Thus, the electric current is directed from the source 22 to the pole windings of the rotor I. so that the l6 poles are magnetized and create a magnetic field, the lines of which pass through the primary circuit 6 and secondary circuit 4 of the stator.
The fixed commutator 9 surrounds the shaft i8 and is provided with a number of conductive segments which are insulated from each other. The rotating brush holder I9 is ​​rigidly fixed to the shaft l8 and can rotate with it. The brush holder is equipped with a plurality of rotating brushes 2, which rest against the segments of the fixed collector 9. The brushes l2 are connected at point a by slip rings l3. The fixed brushes [0, the ends of which abut against the fixed slip rings :3, are connected to a DC source 22 by conductors 2.
skybiker63
 :o I wonder why noone tried to buil this Ion Motor from the past. No need for new engineering.
kolbacict
Tried to. :)
Please note that Slobodyan's video, which I posted a week ago, also has eight stator poles and four brushes.   All this was ignored.   :(
skybiker63
So lets do it together. I can support the ion motor by building all parts. Have all necessary conections. Perhaps someone else would like to join such  Team.
skybiker63
A 1935 technology without any electronic parts should be not so complicated.
