Ufopolitics
Quote from: rakarskiy on July 03, 2022, 03:18:39 AM
Another interesting patent!
"Motor generator and other transformer" - 1935-11-19  Publication of US2021177A
https://patents.google.com/patent/US2021177?oq=US2021177
Hello
This is a waste of time.
We went through that Patent (in detail) back on 2011-2012...on My Asymmetric Machines at Energetic Forum, because of its similarities in structure.
But it is basically a DC to AC Converter (Inverter) where the DC Motor converts into AC by induction transfer of both windings (DC-AC) within armature core...slip rings collect AC at the other side of shaft.
And they did build some prototypes into production...nothing more than a Electro-mechanical inverter, ruled by the basic Ohm Law...no OU here.
Sincerely
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
rakarskiy
Quote from: Ufopolitics on July 03, 2022, 01:57:53 PM
Hello
Sincerely
Ufopolitics
https://rakatskiy.blogspot.com/2021/02/mystery-nikola-teslas-electric-car.html?m=1
Jimboot
Quote from: Ufopolitics on July 02, 2022, 12:54:56 PM
Hey Jim,
If you are getting canceled out in parallel it is because you have end-start in one point out, and end-start on second point out, so they will cancel.
Each coil or circuit of series coils always have a Start and an End terminal.
For Parallel output, it must be start with start and End with End.
So, try reversing just one of the two circuits terminals (Exciter or Main Out) and reconnect.
Ufopolitics
I checked polarity before posting.. cannot get the effect with two in parallel.
Jimboot
Ran the halogen test again. I'll be surprised if my amp reading is correct but there is over a 40 c temp diff with using the generator.
onepower
rakarskiy
Quotehttps://rakatskiy.blogspot.com/2021/02/mystery-nikola-teslas-electric-car.html?m=1
You did a really good job on that article.
QuoteAlexander and Smith were unable to fully explain how this energy is obtained from "nothing", however, they noted that people have long been able to do much more than they know and understand, and go far to find unnecessary examples - just look on this car that drives. The inventors called the demonstrated phenomenon "superpower" because it uses three types of energy to achieve this goal.
The design is based on a transformer (converter), which is also the rotor of a generator (crossed by a magnetic flux). The AC output is the result of two electromagnetic influences. Recall that the rate of change of acceleration - the third derivative of the coordinate - is a jerk.
The rotor is a transformer core and has a group of paired windings. Each section of the rotor has two windings, one of which works as the primary winding of the transformer and as the motor winding, and the other as the secondary winding of the transformer and as the generator winding. In this case, only permanent magnets are located on the stator.
This is a common theme and countless inventors have claimed it's a transformer but not a transformer. As well, as you pointed out, almost all of these inventors had no idea where the energy was coming from. We know it must come from somewhere however it remains a mystery...
AC
