rakarskiy
Quote from: onepower on July 04, 2022, 01:40:23 AM
rakarskiy
You did a really good job on that article.
This is a common theme and countless inventors have claimed it's a transformer but not a transformer. As well, as you pointed out, almost all of these inventors had no idea where the energy was coming from. We know it must come from somewhere however it remains a mystery...
AC
Interesting question, isn't it! And where does the energy in a traditional mechanical synchronous generator come from?
Once again, I recommend reading and understanding!
https://rakatskiy.blogspot.com/2022/06/magnetization-of-steel-magnetic.html
kolbacict
I ask, is a single-phase electric motor with not three, but with two windings and a phase-shifting capacitor suitable for your experiments?
Similar to the Soviet  "СД-54" ?
Jimboot
My current measurements are definitely wrong. I need a variac but in the meantime I'll resort to excess heat measurements. The lamp should be easy but the power supply a little trickier. I think a 10 minute duration for the tests then wait until both lamp and supply are back at room temp before conducting the next test. I have a dmm probe for the lamp and an infrared thermometer for the supply. I should be able to calibrate before hand by hitting the thermistor probe with the IR gun.
rakarskiy
Quote from: Jimboot on July 04, 2022, 04:29:37 AM
Jimboot, measure the heating power of the lamp, there will be even greater inaccuracies.
You need to measure all the resistances: rotor windings, generator windings, loads.
Next, the open circuit voltage of the AC voltage source; voltage at the rotor terminals when the generator is turned on with an open circuit. Rotor terminal voltage with phase load on. If there is an ammeter, the current strength at idle and with a load.
Further - the voltage at the terminals of the generator without load, the voltage at the terminals of the generator with a load, if possible, the current strength in the phase and load circuit in both inclusions.
With these data it is quite possible to determine the effectiveness of your experiment.
rakarskiy
Quote from: kolbacict on July 04, 2022, 04:20:24 AM
Use the engines for their intended purpose. For the experiment, a pair of rotor + stator from a single-phase generator is needed, which are installed in gas generators.
