0 Members and 82 Guests are viewing this topic.
bistander
Hey Ufo,
I'm not accusing you of anything. Photos show a wire (test lead) passing through the clamp ammeter then to one terminal of the lamp. Lamp appears off. Meter reads ~ 6 amps. Assumption is that lamp typically glows at 6A or less.
That's fishy, meaning something unusual is happening. What do you think it is? Did you put another ammeter on/in the circuit to check? What was the ammeter reading when the test lead was unclipped from the lamp? Heavy solar activity that day? Invisible light from the lamp? Is it repeatable? Does the lamp operate normally elsewhere? Is the battery in the ammeter fresh? File it under unexplainable or do a press release to claim overunity. Good luck.
bi
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
Ufopolitics
Quote from: bistander on July 05, 2022, 05:21:30 PM
Hey Ufo,
Nope, negative, this 120V/60Watts Lamp will not even dim at 6A and 7.0 Volts AC...
Quote from: bistander on July 05, 2022, 05:21:30 PMThat's fishy, meaning something unusual is happening. What do you think it is? Did you put another ammeter on/in the circuit to check? What was the ammeter reading when the test lead was unclipped from the lamp? Heavy solar activity that day? Invisible light from the lamp? Is it repeatable? Does the lamp operate normally elsewhere? Is the battery in the ammeter fresh? File it under unexplainable or do a press release to claim overunity. Good luck.
bi
Ok,
;D ...I have not claimed OU...it is not, let's just call it "an anomaly".
Later, am done for today.
And you know what?...I just remember, I have a video taken around 6 or 7 years ago...where something similar took place, related to amperage increase over input, but voltage was too low, when I was collapsing the field...and I uploaded it, then...but I believe it was unlisted...have to look for it.
tomorrow
Ufopolitics
―Leonardo da Vinci
Ufopolitics
Hey Ufo
bi
It is simply showing me the way to achieve this same effect in a more "controlable" way...
Remember I built that Rotary switch from scratch...
Later
―Leonardo da Vinci
Jimboot
Quote from: Ufopolitics on July 05, 2022, 05:53:04 PM
Later
Nice work! My halogen will not light at all on 24VAC power supply. Adding more capacitance on the stator side increases the brightness. Have you tried different lamp types? Thanks for the share.
