0 Members and 75 Guests are viewing this topic.
rakarskiy
Quote from: kolbacict on July 06, 2022, 01:55:40 AM
What is this about?  I did not know this law.
I thought that the internal resistance of the power supply should ideally be zero.
You are absolutely right, the source resistance should tend to zero.
Moreover, the idling EMF should conditionally be twice the voltage at the generator terminals under load. The voltage drop to the mains voltage is the CURRENT POWER that you want to get. So some kind of Jacobi law is just a utopia.
kolbacict
After all, it is possible to create your rotating magnetic field with such a stator.
It remains only to make a suitable "rotor" secondary winding.
After all, it will, right ?
alan
Quote from: kolbacict on July 06, 2022, 04:35:25 AM
Try this (based on DZ & holcomb vid):
N-S-N-S 90 degrees spaced, so N facing N and S facing S.
Create a simple secondary coil (first, maybe a partnered coil later to cancel self-induced fields) with the length fitting the diameter of the hole, position it like that inside.
ariovaldo
Quote from: alan on July 06, 2022, 05:37:24 AM
Yap
ariovaldo
In 2018 when I took over as maintenance manager in a big corporation, I got rid of my tools, parts, and everything related to the experiments I had been doing since 2006.
Meantime I used to check the 'OverUnity" forum community and the Holcomb topic called my attention for so many reasons, explaining some anomalies that I noticed in the past in my experiments.
Now I'm getting everything back, and I will re-start my tests.
