Floor
"By eliminating reverse torque, the Holcomb Energy System generates significantly more
power output than is required to operate the system. This allows the HES to recycle a portion
of that power output through a standard capacitor/battery interface in a self-regenerating
fashion, while simultaneously powering an electrical load. "
"In the Holcomb Energy System, the rotating armature/rotor of the standard electric power
generator has been replaced with a static rotor mechanism constructed of multiple
electromagnetic pole pieces which are sequenced by a computer excitation system and
solid-state relays. The poles are sequenced such that in the case of the 3-phase, 50 Hz
generator, 4 distinct alternating poles rotate at 1500 rpm. Unlike the rotating armature in
a conventional generator, the rotating magnetic poles in the HES are static. Therefore, the
Holcomb Energy System operates with no moving parts – it is entirely solid-state and
scalable to any application. "
"when a coil of magnet wire is wrapped around the electrical steel, and a weak current is
passed through the coil, the coil generates a weak magnetic field which aligns the
magnetic domains of the steel, and as the domains are aligned, they produce powerful,
moving, magnetic flux which, when organized and sequenced by our high speed computer
system, generates four powerful spinning magnetic poles which pushes electrons around
through the stator coils, producing clean, 3-phase power. Therefore, the weak magnetic
field generated by the power input creates powerful moving magnetic fields which are
responsible for generating the electric power. "
"However, the standard generator rotor only aligns the domains one time at start-up, and
then gets no further energy advantage from the aligning process. In comparison, the HES
aligns the domains and relaxes the alignment, and re-aligns and relaxes continuously every
4 milliseconds. Therefore we get the magnification effect 250 times per second. "
Sounds like a transformer to me, and seems like it must have plenty of back EMf.
Quote from: Floor on March 24, 2022, 09:21:07 PM
power output than is required to operate the system. This allows the HES to recycle a portion of that power output through a standard capacitor/battery interface in a self-regenerating fashion, while simultaneously powering an electrical load. "
"In the Holcomb Energy System, the rotating armature/rotor of the standard electric power generator has been replaced with a static rotor mechanism constructed of multiple electromagnetic pole pieces which are sequenced by a computer excitation system and solid-state relays. The poles are sequenced such that in the case of the 3-phase, 50 Hz generator, 4 distinct alternating poles rotate at 1500 rpm. Unlike the rotating armature in a conventional generator, the rotating magnetic poles in the HES are static. Therefore, the Holcomb Energy System operates with no moving parts – it is entirely solid-state and scalable to any
application. "
"when a coil of magnet wire is wrapped around the electrical steel, and a weak current is passed through the coil, the coil generates a weak magnetic field which aligns the magnetic domains of the steel, and as the domains are aligned, they produce powerful, moving, magnetic flux which, when organized and sequenced by our high speed computer system, generates four powerful spinning magnetic poles which pushes electrons around through the stator coils, producing clean, 3-phase power. Therefore, the weak magnetic field generated by the power input creates powerful moving magnetic fields which are responsible for generating the electric power. "
"However, the standard generator rotor only aligns the domains one time at start-up, and then gets no further energy advantage from the aligning process. In comparison, the HES aligns the domains and relaxes the alignment, and re-aligns and relaxes continuously every 4 milliseconds. Therefore we get the magnification effect 250 times per second. "
Does "new invention" violate an AXIOM,a law or an Order or it is "only based" by
applied geral ? specific ? absolute ? THEOREM  AXIOMS,Laws,Orders their "conditonized Freedom degrees " !
https://de.wikipedia.org/wiki/Theorem
https://de-m-wikipedia-org.translate.goog/wiki/Theorem?_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=wapp
German language and meaning RANDOM
English language translation and meaning RANDOM (human or automatic translator dependent)
Saxon      "                "                      "               "             "                 "                "                "
https://en.wiktionary.org/wiki/Saxon
(Ireland, Wales, poetic) An English/British person.
polylingual,polyintelligent : in analytics a need !
3 scientists in meeting = up to 5 opinions ! [ ? in-/out-sid(e/ing)] 8) Coming from everywhere,with different school/Uni education styles !
Brain- Analytics,human (m./f./n. experiments)brains(indiv. polybrainsorg and use ! or not  ;D ) - https://en.wikipedia.org/wiki/Deterministic_system
             Em-/Parasym-/Sym-/Ek-Pathie : all in one  " solar  ;) (com) plexus "
http://www.rexresearch.com/ide/thetipofaniceberg.pdf
For example, Holcomb object concurrence :
http://www.rexresearch.com/ide/ide.htm
commercial :
Priority date(s),application geopolitical validity
only material parts costs/ mass small-serie exploration calculation !
Ultra-low margin,beside global average costs R&D R.O.I. !
Feb2006
4 distinct alternating poles ROTATE at 1500 rpm.
Sounds like a generator to me.
