kolbacict
Quote from: seychelles on July 06, 2022, 09:52:02 PM
THE OUT PUT CORE IS BEING MODULATED FROM BOTH ENDS.
Similar to the picture that Rakarsky showed?
Where is the "stator" outside and inside?
p.s.
It is you?
seychelles
alan
one of the secret of this device is that THE OUT PUT CORE IS BEING MODULATED FROM BOTH ENDS.
I WOULD ASSUME THAT GENERATE A MAGNETIC TORNADO WITHIN THE INNER CORE.
Yeah! Floyd Sweed also called it flux modulation.
A mechanical setup with a very simple (N-S-N-S 90deg) rotor outside the coil may be an interesting experiment to study Lenz and to see if the tornado also causes zero backtorque, since, per claim, it wouldn't create back emf in the solid state setup.
kolbacict
Quote from: alan on July 06, 2022, 11:27:49 AM
The B-field induced by self-inductance of the secondary, aka Lenz, is always there if there's a current. Maybe this way it has no effect on the moving field, but I can't prove it.
Okay, let's not get rid of Lenz in any case, but is it possible to configure the secondary winding so that it is indifferent to that component of the field, which changes only in time, but is stationary?
p.s.
I know impedance matching is important for radio frequencies. Including the characteristic impedance of the transmission line.
For 50/60 Hz. is that important too? :o
alan
Quote from: kolbacict on July 07, 2022, 06:54:54 AM
p.s.
Maybe the configuration is already doing that, the time rate of change of the number of flux lines is net zero, but moving nonetheless.  Or perhaps the coils are wound as a non-(self!)inductive coil, bifilar.
Just speculating.
Impedance matching for 50/60hz depends on the impedance and the application, I don't think anyone is doing that for power conversion.
