Feb2006
From patent application WO 2018/134233 A2
"3. Shielding: A stator armature iron also contains a series of mu metal shields
between wire slots, which allow flux linkage between narrow segments of side iron and back
iron and a uni-pole rotor flux such that an armature coil inductive power generation may be
attained. (Mu metal can, for example, be an annealed metal of 75% nickel, 15% iron, plus
copper, and molybdenum.) However, no significant reverse torque is developed."
"FIG. 10 illustrates hard power pack protective case 49 with the outer protective cover
removed, revealing the mu metal foil shield 71 on the generator. The mu metal foil shield
deflects the armature flux at right angles and encourages the armature flux line to progress
across the stator coils."
"FIG. 14 illustrates a side view of the hard power pack protective case of a fully
assembled smartphone with armature and stator of the high efficiency generator installed with
mu metal foil in place covering the back and sides of the stator, consistent with embodiments
of the disclosure"
"FIG. 21 depicts stator 63 pressed against armature 59; armature pole windings preformed coils 61, 60;
armature coil leads 61L and 60L; North pole flux 58(1)-58(4) and South
pole flux 58(1)-58(4) generated by and emanating from armature 59 as described above into
stator 63 and its lap wound stator coils 70; mu metal shield 71; and power leads 62a and 62b.
Power leads 62a and 62b conduct the DC power generated by the solid state generator and is
carried to an electrical load, such as a smart phone or other battery-operated electrical device"
This makes me wonder if the mu metal shield is essential or only enhances the operation?
ariovaldo
Quote from: Feb2006 on July 11, 2022, 12:26:09 PM
of the disclosure"
I do think that we can find the effects without the MU-metal. Probably it is to enhance the machine COP
ramset
Just a note to ariovaldo ( longtime researcher and builder )
Here Stefan has made a section for research/builders sharing their work!
And many do get frustrated trying to run a build topic on main board ( unmanaged areas)
Please keep this in mind ,it gives  you ability to update all pages and manage content
also can be locked for safe keeping and updates ( or benchmark breakthrough topic for "please replicate" etc)
And many topics can be opened !
Those who take the time to share their hard work and time deserve this forum feature!
Available to all builders ( and also persons like member Solarlab doing aggressive research towards
A build )
It has made all the difference in builders topics !
Respectfully
Chet K
Ps
Pm Stefan for this
If any issues send me a pm
Sorry for interruption!!
Thanks Grandma
kolbacict
Someone will answer me, in the end, why does the secondary winding need to be placed on another part, another yoke ? Separated from the primary yoke by air gap, moreover, which worsens the parameters ?  Why is it impossible to wind the secondary winding in the same place, and close the poles with a magnetic circuit ?  Is there a fundamental need for this ?
