Energy Generation by moving Mag Field through Static Steel Core & Copper Coils
Started by Ufopolitics, April 07, 2022, 09:40:19 AM
Ufopolitics
Quote from: Semi on April 25, 2022, 03:08:18 AM
This can't be true, not at all. I've read values from an AVR, that excites up to 90 VDC depending on the load, Output approx. 230V AC.
Have you read the Voltage from AVR when the Generator was loaded?
With a heavy load?, not just a couple of LED's or a small fan... ;D
When the Generator is at "Idle" the AVR reduces to minimal its excitation circuit.
The "230V" Output is just based on a Double Winding at Stator, which collects double the output based on exactly the SAME EXCITING FIELD SWEEP.
The exact same way we could get Three Phase Out...
Well, I thought your 4 Brushes will create an equally divided 4 Pole RMF?
Nope, I already explained why I used Four Brushes...read my prior posts where I show my image of the 4 brushes...
So I derived my Math from that. If you have "just" a 2 Pole RMF, with 24 Coils,
you would've to go even faster. Then it would be: 24 x T_RMF = T_2P => 24 x f_2P = f_RMF => 24 x 50 Hz = 1200 Hz -> T_RMF = 0,83 ms
Yes, it is totally possible that I am barking up the wrong tree here. That is why I wanted you to double-check this on your rig.
I totally get you there...
How much more theoretically can I get, when not by using Math? You have the Test rig already, why not getting some data out of it?
So you derived your math above from a wrong assumption, so, everything is wrong.
Perhaps I don't get the detailed Setup configuration you have built. I felt into the assumption trap, again.
Here my thoughts about this, please correct me...
If you have a Rotor with 24 Bars on the commutator, you will spin your brushes
around these 24 contacts. If equally divided, with 2 Brushes, you will create a 2 Pole RMF and with 4 Brushes, you will create a 4 Pole RMF.
Thanks for taking the time, very much appreciated.
Semi
Again, wrong assumption, maybe because not reading carefully my previous post...but no sweat...I will repost it here...without the pictures:
Quote from: Ufopolitics on April 17, 2022, 05:58:07 PM
But the main issue here that I want to share, is how I have set the brushes on the rotary switch...yesterday, I was testing with just two brushes...and there was a lot of sparking, a lot of BEMF returning back to Input PSU...
So I decided to close the Field Range by adding four brushes (this brush housing on switch, was designed for 4 brushes) but they have to be in a way that is NOT as Motors have it.
Normally a four brush motor will have an arrangement of /+/-/+/- / and that way the field gets split into Four Fields at the Rotor.
However, I did it in order to keep just one field, but close its angle at the Poles, by setting brushes like: /+/+/-/-/ , therefore, the coils within the two plus (+) and two minus (-) will not be energized, not generating a field, but just conducting power...and so, Field Spectrum is way much cleaner.
Magnetic Field will not have any "scrambling" which happens with just two brushes...and it is due to coils at the contacts (+/-) will be intersecting with BOTH main poles...I will make next week a CAD to show what I mean, however, on my previous image here that have an armature, wound with lap windings, you can see that I colored these next to input plus and minus in a different color (magenta) than all the red-blue coils defining the North-South Poles.
Cheers
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
Ufopolitics
Hello to All,
My present update plus some "secrets" revealed:
I had some bad testing as also very good ones...
The bad tests I consider very important as well as the successful ones, as they teach Us what is NOT allowed, or not good on these Systems...
For example, the German Groschopp Universal Motor was a total failure!!
Why?
Its Armature-Rotor is simply an "Amp Hog"...it consumes higher amperages than volts, as I dialed up just voltage (V.L), while Current is all the way high ...and I tried with both PSU's...a switching and a Linear.
On both reacted the same exact way...
And it does spin the Field, however, the field generated is not strong enough as we loose a lot of power just on the Input.
The reason for this effect is simple, is wound with too thick gauge wire and just a few turns per coil...
The first successful test with the RYOBI Hand Tool 230 (HT230) [on short test video] had very fine wire and many turns...
So I tried another setup, with a 12 tooth armature, and the typical Simplex Lap Winding, and wire gauge 23...I am attaching an image of this winding below...
It did not work either...the sine wave projected on Scope was not uniform and the output results were also not good...
So, I went back to the original RYOBI armature which worked fine...and analyzed deeper the way it was wound...and it is a completely different type of winding as I did previously...if you notice, (picture attached) it ends with two identical coils opposed at 180 degrees.
Plus, the rotor core have 8 slots (tooth) and the commutator have 16 elements...
Note: I did NOT want to take apart my only working armature, first because it is soaked in resin...and second, because we never should take apart a working model...take it as an advice!!
So, I started searching and found this video from a guy, (I believe He is from India)... winding a Power Tool...which have 16 slots and 32 Commutator bars from an angle grinder...So, without understanding a single word he was talking about...I learned the way it was done:
VIDEO: THE SUCCESSFUL WAY TO WIND THE ARMATURE
The way these type of armatures are wound is very different from the typical "Spiral" type...that we start just ONE COIL and keep winding series coils next to each others...untill we meet the first wire at commutator.
On this successful type, we need to WIND BOTH SIDES COILS, apart by 180 degrees, and keep going in a follow up pattern, until we meet both ends,  also apart by 180º...
But that is not all...each coil have the second coil right on top of each other, except the second coil on top, connects to the next commutator segment on the follow up sequence...
And this rises the Field Strength exponentially!!...just like a double threaded wire in a coil does, except, by just a few milliseconds of time difference.
I will show on further posts the detailed Graphics related to this type of winding...
Plus, I have been able to adapt this type of winding to many other armature patterns, like 12 and 20 tooth...which ends in exactly 16 contacts to my Rotary Switch...so, no coils are not connected during operation.
Ufopolitics
―Leonardo da Vinci
Ufopolitics
ADAPTING A 12 TOOTH ARMATURE TO 8 DOUBLE COILS - 16 TERMINALS
This is one of my armatures, it is wound with 28 gauge, and works beautifully!!
I wound each coil with 40 Turns...
I can dial as high as 100 Volts+ and Amperage remains around 1-2 amps...lovely Field!!
But as I increase RPM's of Field Rotation, amperage decreases.
THE METHOD EXPLAINED, ACCORDING TO GRAPHIC SHOWN:
I start by the Two Pairs of Blue Coils shown (1-2 & 9-10), each pair exactly apart by 180º...while these would be my 1.2 9, 10 terminals to rotary switch...
After done with all four coils, I come back to wind Coils 3-4 and 11-12...
And so on, following the red arrows orderly sequence, for coils winding, as for terminals to rotary switch.
Finally I will end up with two Pair of end Coils 15-16 and 7-8 exactly apart by 180º...(see picture attached)
I am actually working on a 20 Pole adapt...to this same pettern, but a bigger set up, so it requires higher number of turns...more steel, more turns.
Whoever is following this posts...and replicating them...will have a lot of fun in the end...
Get ready for ¨surprises¨ coming very soon... ;D
Ufopolitics
―Leonardo da Vinci
Ufopolitics
VISUALIZING THE VIRTUAL MAGNETIC FIELD ROTATING
On above Video link, you will be able to see the Field Rotating through three different Methods...
I have developed a way to distinguish Polarizations in any given Magnetic Field through an old CRT (Cathode Ray Tube) Black and white small TV...
The Electron Beam Ray sweeping screen at very high frequency in a Horizontal Line...shows clearly the Two different Patterns which defines a NORTH  from a South.
BUILDING YOUR OWN CRT MAG FIELD SCOPE
On above video link you will learn how to build one for yourself...
And on the Video below, you will see the Full Video on how this is achieved...
CRT REVEALING MAGNETIC FIELD VORTEXES
By the way, the Armature shown on first video demo, is the one I have shown previously...a 12T wound with 16 coils
Cheers
Ufopolitics
―Leonardo da Vinci
