Just another Don Smith thread
Started by nix85, April 11, 2022, 10:54:51 AM
Vortex 22
My recommendation
For building the basic
Capacitor electrons Captor?
Just try to find:
-2 diodes or full bridge rectifier ( say 300 voltage)
-Capacitor ( polar cap 400 volts and 300 micro farads or less
Using the mains ( 220 v and 50 Hz)
If you have SWER system type? Single wire earth return in your city?
Than you must avoid the earth grounding
In this case
We can grounding this circuit on jag of water 🌊
Hold questions until after you have done what has been suggested. I say it like this because once you have built
it, all your questions will anwser themselves.
Electricity is very dangerous,  be careful
Please
Show me your setup, so I can guide you more !
Vortex 22
Vortex 22
We can add also
Multimeter DC voltage to display the voltage that we have capture?
Be careful please
nix85
Funny how some mention same cap value shown in the last
video i shared (and later removed), hmm, coincidence or.
In any case Barbosa is a questionable one, many say it is but meter
cheater, bypassing the neutral by connecting to a pole in the ground.
This of course instantly trips the RCD if you have one which you probably do.
This guy did just that, bypassed the RCD temporarily and what he shows
looks like free energy but is just meter cheating.
https://www.youtube.com/watch?v=wbNvUZT4NC4
Of course whole device in this case is a redundant sham, one can simply
connect the load to leads before the power meter and meter is bypassed
i suggested this to a friend years ago who wanted to reduce heating
electricity bill in the winter and he did this and voilĂ . Few years before
that i also found a big neodymium, 5x5x5cm something like that, and
it almost completely stopped his meter, this was in another location,
no matter what load, but meter vibrated all the time, he had to put
insulation around it and it could still be heard it was really intense.
In any case question is why he has that RCD behind the power meter
when he had to bypass RCD, as he says
"in the switch panel I had to make
a separate group otherwise it didn't
work doesn't there's an issue with the
RCD switch the device tripped all the
time so I had to make a bypass"
On the other hand original Barbosa allegedly did it from a battery, so
this would imply it is not meter cheating.
Vortex 22
Barbosa and leal device works very well
With no high voltage for the battery electrons Captor !!!
nix85
Barbosa shown in the video is just bypassing the meter.
Like i said, original Barbosa allegedly did it from a battery
which implies it is not meter-cheating.
Here is one alleged barbosa replications,
48.5W in 2450W out.
https://www.youtube.com/watch?v=l9BGBvDEkiw
Only way to be SURE it is not meter bypassing
is to run it from a battery, i have not seen such.
