Just another Don Smith thread
Started by nix85, April 11, 2022, 10:54:51 AM
AlienGrey
Yes i have been telling them this on here for years, all i got was abuse from some corners over it!
Regards Sil
nix85
Gotta keep in mind this table can be extended to the right, below is an
example with one additional column. Question is if this 9th column corresponds
to a musical note (harmonics).
Probably does. What about further extension.
So it's not really an explanation of 8 tonal division but i believe it is very
closely related.
Also what about the so called Pythagorean comma, according to common opinion
there is no perfect octave in Pythagorean scale, each next octave is bit off, but
this table shows Pythagorean scale, 1.5 ratio (perfect 5th) is respected and octaves
are perfect multiples so what do they mean, maybe it's because they usually start
with A440 which has all irrational frequencies so that messes things up.
https://www.youtube.com/watch?v=Da_v13Ncyb4
nix85
Notice in the table numerical value for all octaves of G alternates
36363636363636....which is also 9.
First column C has numerical values 1,2,4,8,7,5,1,2,4,8,7,5,1,2...
And we can see it is also a repeating pattern 124875 which has numerical
value 9, ALL ARE NINE!
ramset
Sir's
Here Dave L shares some work and actually recommends experiments to readers ?
https://www.overunityresearch.com/index.php?topic=4284.msg98895;topicseen#msg98895
Perhaps peruse his content ( other topics)
While he does not fill forum with many every day contributions
His work ( and others in his topic) is there to ponder !
Do you have experiment of your own to share that would jump out to science as unusual?
Yes I have seen many you tubes of others you ( Nix) have posted as OU claims
However none has been investigated through peer review or even replicated
At few open source venues such as this ...with thousands of potential replicators
Of ALL sciences and skill sets !!
Just one simple anomaly that will survive scientific scrutiny ( proper measurement protocols) will do... tiny piece of meat ( signal) with the potatoes ( fill /static) .
Respectfully
Chet K
Ps
For clarity this is not advertising
Neither this forum or one posted above is commercial business venture ( no advertising)
Just open source venue to get this FE out to world ( once truly found )
PLEASE HELP !!
Edit for comment below
That is a "sideways contribution " ( side stepping)
Who said anything about doubt !!
Here you preach to hungry choir !!
However, yes they do have good and honest vetting skills !
Just one anomaly will do !
Thanks Grandma
nix85
I studied Wilbert Smith for long time, Project Magnet etc. He did lots of experiments with caduceus coils, one i remember he said they were putting 4kW into this coil, energy apparently disappearing without heat or anything. He also did some mechanical antigravity attempts, i remember his device exploded from centrifugal force when it reached 20,000 rpm if i remember correctly. He spoke of 12 dimensions etc.
As for OU, all has been said. Doubt only leads to failure, that is the dividing line.
Edit for comment above...
It's no side-stepping, how am i supposed to help you, i did not even do it myself yet.
One has to believe (see) and put a hard work in, no shortcuts.
