re. Vapor Carburetor Series by Tommy Reed @ T.R.Labs
Started by Floor, May 02, 2022, 07:09:52 PM
Floor
Quote from
https://overunity.com/19101/vapor-carburetor-series/msg566429/#msg566429
"Hello All,
New update.
https://www.youtube.com/watch?v=1IE8g-crLZ8 "
End of that quote
Co2 and atmospheric gases mixing  @ 7 minutes and 37 seconds into the video.
Composition of Earth"s atmoshpere.
https://www.geeksforgeeks.org/composition-and-structure-of-earths-atmosphere/
Atmospheric pressure
https://en.wikipedia.org/wiki/Atmospheric_pressure
Diameter of Earth is 7,926.3 miles
Thickness of Earth's atmosphere  is about 1 / 133 of the diameter of Earth.
https://www.grc.nasa.gov/WWW/k-12/airplane/atmosphere.html
       By comparison...
A professional NBA basketball has a diameter between 9.43"-9.51" | 24-24.2 cm.
9.5 inches divided by 133 = Earth's atmosphere is then  0.07125 inch thick.
                    note.  the inhabitable layer of the atmosphere is much thinner.
Thickness of Earth's      inhabitable ?      atmosphere  is about
1 / 665 of the diameter of Earth.
       By comparison...
9.5 inches divided by 665 is Earth's          inhabitable     atmosphere. Which is then
about 0.014285 inch thick.
Height of Mount Everest 8,848.86 m (29,031.7 ft)
               or 5.4984 miles.
The altitude of the "death zone" is  above 26,000 ft or about  4.92424 miles
       https://en.wikipedia.org/wiki/Death_zone
7,926.3 mi  /  4.92424 mi  =  1 / 1609.64940 of the diameter of the earth.
As compared to a basket ball the inhabitable  atmosphere is about 0.00590 of an inch thick.
The thickness of saran wrap is roughly 0.01 mm or 0.000393 inch thick.
As compared to a basket ball the  inhabitable atmosphere is about 15 layers of saran wrap.
https://scied.ucar.edu/activity/learn/atmospheric-layers
This layer, where the Earth's weather occurs, is within about 10 km (6 miles) of the
Earth's surface. The stratosphere goes up to about 50 km (31 miles).
Density of Carbon Dioxide.
https://www.engineeringtoolbox.com/carbon-dioxide-density-specific-weight-temperature-pressure-d_2018.html
Density of Nitrogen
https://www.engineeringtoolbox.com/nitrogen-N2-density-specific-weight-temperature-pressure-d_2039.html
Density of Oxygen
https://www.engineeringtoolbox.com/oxygen-O2-density-specific-weight-temperature-pressure-d_2082.html
Gases with different densities mixing together
https://www.quora.com/Why-dont-the-different-gases-in-the-atmosphere-separate
Gas dispersion
https://www.draeger.com/library/content/gas_dispersion_br_9046434_en.pdf
Dispersion characteristics of CO2
https://www.sciencedirect.com/science/article/abs/pii/S1875510019303087
Atmospheric Carbon Dioxide
https://www.climate.gov/news-features/understanding-climate/climate-change-atmospheric-carbon-dioxide
Floor
A momentatry aside from Tommy Reed's (transition Tech. topic)
40 MPG gas on a Ford 302 engine (aspirated / carburetor)
but without any fuel preheating.
3rd video of 3 @
https://www.youtube.com/watch?v=1xHQWu2ZzPc
Floor
@ Ramset
To be clear...
My post / topic (right here) @
https://overunity.com/19102/re-vapor-carburetor-series-by-tommy-reed-t-r-labs/msg566442/#msg566442
Was first posted @
It was deleted while I was editing it / post editing it.
I wasn't even / at first aware that my post was removed.
Then, I thought it was some tech. mistake on my part / bad key stroke ?
I re posted it and went to edited it more.
It was deleted again.
It seems that one cannot edit a post that no longer exists.
Then..
           The topic was locked.
Realizing it was being deleted I posted it outside of that topic that is all.
                         Which is totally, the  appropriate thing to do.
"Each board can also have many different Threads, but the Builder will also be the moderator in all these Threads of his board...so remember this.  He has the power then to delete messages he does not like. If you want to criticize him in any aspect or find an error in his work, you should be friendly and let him know. If he does not like your critics and deletes it, you can only save your posting and then post it again into another board, where the builder has no moderator rights  and discuss it over there. this case I can not retrieve your critics postings, as it was already deleted, so better save your postings on your own hard disk, before you post it to the forum for later retrieval...
But I hope this will be all going in a good and friendly manner and people will not fall out over each other and donĀ“t start name calling  and flame wars. "
                                                        AND
     I stand by it, and a moderator's freedom to delete my posts in his own topics.
Have you read this ? https://overunity.com/19102/re-vapor-carburetor-series-by-tommy-reed-t-r-labs/msg566468/#new
                                       The topic is NOT about Tommy Reed.
I don't know Tommy read, I have no experience of him other than having just watched
his recent videos,            and             I have not created a topic about him.
I posted a response to a video.
I titled it as such (the name of the topic and the name of the BOARD it is a response to),
that is all           and          that was and is           all it is intended to be.
                                        Why does anyone have a problem with that ?
It is not a "fight" on my part, just a / the posting of a relevant response to a particular
statement in a particular video.
Who ever is  projecting something that isn't there on my part,
                    well, that's just their projection !
   floor
ramset
Wonderful example ,entitlement extraordinaire !
Interrupting an investigation at every whim !
I would imagine we could completely fill forum with off topic posts and topics on every -moment-
Of a given presentation!
Like persons barking out comments in the middle of a movie ( too important or impatient to wait until
The end !!
_Look at me _ can be so much fun !!
Sorry this is horrible example
Asking a person to PM prior to comments ( as was done by presenter )
And then ignoring ?
And starting a topic to post completely unrelated ( none phase change research)
As a critique?( flame war in slow motion ?...
Yeesh
Sorry
If a builder can't set his own standards for engagement (please pm me with questions)
Without bored person's unfamiliar with topic starting mirror topics ( out of spite it seems )
Forum rules will need amending to attract serious builders and researchers!
It is one thing to get out the tools and clean off the bench and show your own efforts in phase change research
Quite another to do what you did here !
I asked you in PM's and email to discuss this
Instead you chose this path
This forum gets buried all to often by nonsense
And while you may feel water fuel is nonsense
I do not  !!and strongly feel it is a play on words ..as water most definitely can do work in the proper
Phase change Environment!!
It can be argued that at some level LENR may be
a phase change of sorts or play some part in yet understood methods !
This is gross !!
Ps
It has always been intent to invite persons here to share their work , this is an open source venue!
If every presentation gets sidetracked with distractions and mirror topics ( not doing similar research )
We need bigger boat !!
I asked Stefan if somehow those persons ( like yourself ) who build and share
Can discuss what to do moving forward...
Perhaps a room for moderators to chat in ?
After all we can't afford to lose builders and researchers , do to miss understanding
Or resolvable issues !
We need all the help we can get !
As well some rules of engagement ( yes ...that will survive scientific scrutiny too
Mostly we need patience in a rapidly evolving venue.. with extremely limited resources ( or people helping admin)
Respectfully
Chet K
Thanks Grandma
ramset
As part of solution , which will not involve me (at this time ..as I have no builder board here)
Stefan is pondering a meeting for builders to attend for input on mirror topics!
And forum etiquette as it applies to this valuable resource!
Next few weeks I hope ..as he is very busy with other things ATM !
The idea ultimately being to invite other presenters here with their work for replication
One very recent example is Inviting David LaPoint
What to do?
And yes I did just receive a reply from your (floor) email
EDIT:Email Discussing things written here early yesterday !
To note above off topic contributions here in this new topic were  removed
Many times by presenter on his builders board
And he posted pm request for discussion with you or any others prior to locking topic ( others were also removed !
I believe you posted one of those unrelated ( to phase change research) vids here too ?
You responded with this path instead of a pm requested by presenter !
All things considered
This is good to sort out !!
It is a huge commitment for builders!! ( yourself obviously)
IMO they are the engines that drive the open source community !
Respectfully
Chet K
Thanks Grandma
