Interesting machine
Started by Question, May 08, 2022, 09:26:23 AM
Question
Here is again the link to our video:
https://www.youtube.com/watch?v=nYb5OkV6_Yo
Please consider carefully and thoroughly the 3-steps procedure below, which additionally explains in some different manner the essence of our invention, and which is situated just below our video.
STEP 1.
1) Four identical bulbs are connected in series to a standard 12 V rectifier thus forming a circuit.
2) These four identical bulbs are bulb 1, bulb 2, bulb 3 and bulb 4, respectively.
3) Bulb 1 is connected immediately after the plus (+) terminal of the rectifier and bulb 4 is connected immediately after the minus (-) terminal of the rectifier. (Bulb 1 and bulb 4 correspond to the two left bulbs in our video and bulb 2 and bulb 3 correspond to the two right bulbs in our video.)
4) The circuit is closed and a direct current flows through the bulbs. All four bulbs glow with the same brightness.
5) Let us use in addition a standard pulse duration modulation system (of constant frequency of 50 Hz for example), which generates 50 identical rectangular current pulses 50 times per second. In this case all four bulbs glow again with the same (but smaller) brightness. The four bulbs are dimmer.
6) The above simple experiment has been carried out hundreds (and may be thousands) of times in our laboratories. You can also repeat this simple experiment even on your kitchen table.
STEP 2.
1) A standard 12 V battery is connected in parallel to the 12 V rectifier.
2) The battery is situated between the two left bulbs (bulb 1 and bulb 4) and the two right bulbs (bulb 2 and bulb 3). In other words, the position of the battery corresponds to the position of the black box of the "upper" circuit 2 in our video.
3) The 12 V standard battery makes the two right bulbs (bulb 2 and bulb 3) glow much brighter than the two left bulbs (bulb 1 and bulb 4).
4) After a certain period of time (several hours of uninterrupted work) however the battery goes dead (is discharged) and all four bulbs glow again with the same brightness. (Please refer to previous STEP 1.)
5) In order to make again the two right bulbs (bulb 2 and bulb 3) glow much brighter than the two left bulbs (bulb 1 and bulb 4) you have either to re-charge the battery or replace it with a new one.
STEP 3.
1) The standard 12 V battery is replaced with a black box and this is actually the "upper" circuit 2 in our video.
2) The black box of the upper circuit 2 is a forever-lasting battery, (a) which never needs re-charging and (b) which makes the two right bulbs (bulb 2 and bulb 3) glow much brighter than the  two left bulbs (bulb 1 and bulb 4) for a practically infinite period of time.
Question
Dear moderator,
What happens here? Why my posts are not published in this forum?
I have already clearly declared that I withdraw my proposal for selling of the black box. Neither business nor any other commercial approach.
Besides I would like to apologize if I have broken some rules of this forum and/or if I have insulted some member of this forum.
Question
Dear AlienGrey,
Your last post seems to me a deliberate cheat, which has been adjusted especially for me? :)
sm0ky2
Why not just say what this 'inexhaustible power source' is?
The first thing anyone would do if they bought a black box is open it to see whats inside
Question
Hi sm0ky2,
Thank you for your reply.
1) First of all let us not talk about buying and selling. I have already promised to the respected moderator and to the respected audience/community of this forum that I will avoid any commercial approach related to the black box.
2) Secondly, do you accept the validity of Step 1 and Step 2 from my post of May 22, 2022, 01:37:59 PM?
