What is overunity?
Started by onepower, June 07, 2022, 04:49:29 PM
Ufopolitics
So far we have been enclosing, enveloping, cloistering that "Super Entity" inside steel and copper...forcing it to spin at "our" very low speeds to generate Energy...and in  some cases we have force that very Dynamic Entity to "stay static"...not to move, while we move steel and copper around it...
By forcing it to "stay still" or to be carried on steel and copper cages like if it was Handicapped...?
When that Entity can travel itself faster than Light?
When that Entity can go through all dense materials like steel and copper in a matter of nanoseconds without causing any heat?
How absurd that process have been so far?
But, finally that Entity would be released...and very free to travel, move, spin at very high speeds...
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
onepower
Ufopolitics
QuoteOverunity is a Mathematical Term, a very simple one...it is part of a "scale" or a range from only three (3) general statistics points, where the center point is "Unity" or Mathematically 1/1, (one unit dividing one unit) of whatever parameters we consider, no restrictions here.
Therefore, the other two points are very simple to understand...Under Unity and Over Unity.
Where the divider of Unity (1) is always set at the lower side or the "divided by"...
The term Unity and overunity also goes much deeper into ancient cultures and technology.
In fact Nikola Tesla and many other inventors were obsessed with the number 3 relating to the "Trinity of Unity" dating back to Sumerian cultures. The trinity of unity relates to the three conditions surrounding the concept of unity, to be born from zero and to die in zero.
That is  +1<<<0>>>-1
and      +1>>>0<<<-1
Or in philosophy any two opposite conditions (male/female, pressure/suction, positive/negative, North/South) generated from something which appears to have neither condition or zero. The zero condition is always found in the center between the two opposite conditions. Like a magnet N<<<0>>>S, or a capacitor/dielectric (+)<<<0>>>(-).
Today we generally call it generation/dissipation of a condition. For example, Protons(+) and electrons(-) close together negate/cancel there external field to become zero, +1>>>0<<<-1. However if we separate the same charges we can produce two distinct positive/negative conditions, +1<<<0>>>-1. Energy is generated from the source +1<<<0>>>-1, then moves towards the the point of dissipation +1>>>0<<<-1. Energy is born from zero and then dies in zero, which is Unity.
In essence this relates to what your talking about with efficiency and COP...
We generate an energy source by separating the zero state into two different conditions having a difference in potential, +1<<<0>>>-1.
We dissipate an energy source by reuniting two different conditions having a difference in potential to become zero, +1>>>0<<<-1.
If we dissipate more energy than we generate it is COP<1 or less than 100%, under unity.
If we generate more energy that we dissipate it is COP>1 or more than 100%, over unity.
If generation equals dissipation COP=1 or 100% efficiency, unity.
So you are correct that Unity (under<<<0>>>over) is a mathematical construct but it was developed by cultures tens of thousands of years ago. It can become a bit of a rabbit hole but the philosophy of the number three and the trinity of unity starts in ancient Sumeria then spreads to ancient Greece, Egypt(Hermes Trismegistus) and India(Vedic, Sanskrit text).
It's actually kind of funny that almost nobody could figure out why Tesla and countless other scientists and inventors were obsessed with the number three. They were all studying the science and technology of these ancient cultures. Throughout the history of mankind these themes keep popping up... the number 3, Unity, the Trinity of Unity.
Now we know the rest of the story and it's really fascinating stuff...
AC
kolbacict
How is this electric motor arranged?
Used in VCRs.
So far no one has been able to answer. ;)
Ufopolitics
Quote from: kolbacict on June 08, 2022, 01:05:10 PM
Used in VCRs.
That is a typical brush motor...and have a servo-speed sensor built inside (a Black-White marked Disk with a photo cell reader)
It was the old ways that they kept speed regulated...
But this is off topic friend.
―Leonardo da Vinci
kolbacict
Quote from: Ufopolitics on June 08, 2022, 09:29:09 AM
That "Entity" is called the Magnetic Field...
The magnetic field does not pass through ferromagnets.Isn't it ?
