Thanks to ALL for your help!!
The breakthrough in Free Energy - a system that cannot be debunked
Started by e2matrix, June 27, 2022, 02:27:39 AM
ramset
Sorry for double post (not just adding to above comment)
It timed out .
I checked through my contacts and Wayne did
Offer open invitation to his place in USA Oklahoma to witness tech !
Going to follow through on that and see if science team
can still See working technology there ?
Yes it is open source "team"
However just a proof it does what is claimed is all that would need to happen ( my opinion at this time)
  If not maybe Stefan or ? Could visit German facility?
After all this claim is impossible by today's science!
And should open investigations into many other possibilities if accurate!
Respectfully
Chet K
Ps
Here a snip from Wayne
Wayne Travis 1 day ago ( explaining workings)
1. the teeter totter is the input cost, there is no pumping of air - the air moved because the pressure between the two sides reverse when the teeter totter changes the head pressure.
2. The cost to move the teeter totter is 50% less than the work out due to the design - specifically where the air volume is reduced by the Travis Effect - less volume to lift - also means less work to sink (50% less in this design).
3. The over 100% value - If I plugged the machine in the wall to drive the teeter totter, it would "appear" to by 200% efficient - because 50KW in produces 100kw out. - but that is an error in interpretation because a "Base Line" is not considered.
3.b  it is part of our physics 'new' discovery is the ability to do work at a cost "below the gravitational standard" and that provable fact is a why our system is real - its a new scope of physics but very very simple to test and verify.
3.C The 100KW is produced is at gravitational  standard - the energy available to leave the machine with each totter - is directly proportional to the "cost reduction" to that the standard- Our system is not a "gain" (even though to the observer - it will look like a gain, feel like a gain, and appear to be a gain - it is a remainder, available at every stroke).
3.D The Travis Effect discovery creates the first known opportunity to design a 10-5=5 system (a remainder system) - not a 10-10=5 which would be over unity or 150%.
3. E Why has energy creation been impossible till now - its the way students were taught - a single focus - In the equation in put / output - the only consideration in physics has been the  output side - some magical gain- my discovery worked on the input side - cost reduction - which is a game changer. Likely a Nobel prize. Hope that helps - and side note - I have since discovered 4 other ways to effect the input to cause a remainder... we love it, the worlds going to change for the better - abundance! Wayne
End quote
Thanks Grandma
ramset
Thanks Grandma
Jimboot
https://patents.google.com/patent/US20210207572A1/en
"                                   Buoyant counterbalance system and method for using same
Abstract
A buoyant counterbalance system and method for using same utilizing a pair of units in fluid communication with each other. Each unit including a tank configured to slidably receive a production ram slidably. A displacement member in a fixed position in relation to the tank and production ram. The displacement member located in the production ram, and defining a first channel including a first piston, and a second channel in communication with an interior of the production ram. A hollow pedestal connected to both of the displacement members, and is configured to communicate a fluid between them. A production line connects to a first side each of the pistons."
plengo
Extremelly interesting finding, the Trevis Effect.
As i watch the videos what comes to my mind all the time is 'capillary action', like an echo of sorts.
This discovery is incredible in so many levels in my opinion, it is so intertwined with my CCs.
