Need help with gravity/buoyancy design
Started by Novus, July 24, 2022, 05:04:29 AM
Tarsier_79
Hi Novus
As I mentioned before, I didn't as yet share the idea on the counterbalance to keep V weightless.
I believe you will find that when using the method to counterbalance V as per the 'Example' given earlier (with the 2nd pulley at twice the distance from the pivot point) you will find a loss equal to the gain in potential gravitational energy of mass M.
So you have an additional counterbalance for the V weight?
Tarsier_79
I have been thinking about the V counterweight. I believe there is a method to counterbalance it with a variable proportional weight.
In #3, the water level raises 12, then 12. The V weight is dropped 8, then 16.
In #5, the water level drops 12, then 12. The V weight is lifted 8 then 16.
The leverage occurs in reverse on the lift and drop. At least the total lift and total drop heights are the same.
A pure mechanical variable solution will be difficult, but probably possible. A simpler (at least for me) method is to have two counterbalance that can occur at different times. We can engage each one when required with a microcontroller. I believe your system already requires one to swap between "scenarios".
Novus
Hi Tarsier,
As it turns out my idea for a counterbalance to keep V weightless at each interval doesn't work.
I'll have a look at you proposal but, since we already agreed that a buoyancy/gravity perpetuum mobile does not and can not exist, I somehow doubt this will work.
I guess we agree that, if only we can find a counterbalance for the part of V at each interval which is not submerged, the system should work.
Tarsier_79
Novus, the solution you proposed initially is unique and interesting. Although I believe a gravity solution is not possible, I try to keep an open mind to an extent, and won't mind finding out if I am wrong.
I believe your method of counterbalance can work in proportion. Both proportions separately.
Novus
QuoteI believe your method of counterbalance can work in proportion. Both proportions separately.
I'm working on a solution which looks promising as per your suggestion. If it works I'll be forwarding the details later today/tomorrow.
