High Speed Motor Generator Test Video and measurement
Started by JackJohn, August 05, 2022, 11:33:15 PM
JackJohn
Just make mini Version of motor generator,
I want to know that Speed could make different
This project is still Unfinished.
This is test Video with measurements of power need by motor driver and Voltage output from 1phase only bldc hard drives motor as generator
Just test supply power need by motor and Voltage output from single phase bldc hard drive as Generator
Let's Check it out
https://dai.ly/x8cw6y9
JackJohn
This is for Diode use to re rectified all phase to single output
On the Video only measurement 1 phase AC
JackJohn
JackJohn
Today I've been upload test Video in English language, if liked my project kindly Follow my Dailymotion Chanel Video
Let's Check it out
>>> https://dai.ly/x8cx41d
JackJohn
Next Continuation will be like this image.
10 BLDC HDD as Generator and on the left and right is 2 pcs High Speed Fan 15K Rpm (15Watt Each) for Drive Motor
The reason I made this project is, because it was inspired by a video from Ludic Science on YouTube which shows an experiment to make a BLDC HDD as a power generator and the results are extraordinary because the BLDC is able to produce +/- 12 Watts of power.
The second reason is because the BLDC HDD has very low cogging so it doesn't require a lot of power to run it without a load (Meaning I can play Freq / rotation speed)
I hope what I say can inspire.
and if you like please follow my Dailymotion Chanel (https://www.dailymotion.com/JackJohn-Device)
