audio amplifier as a power generator (instruction)
Started by dxer_87, September 21, 2022, 03:56:14 PM
dxer_87
Another addon to Paulos Baby, may be used separately lowering the current on neutral. You can give for load, but another circuit will be for this which I am working for.
dxer_87
You can make your own ferrite core, pulverizing (braking existing one) from old tv by hammer in a bowl. then you add butapren like glue (or epoxy) and wood diminutive dry sawdust to keep it together, mix it up and put it in a cement form - or this modern one from foam. This is an old method known in th 80's.
dxer_87
Corrected info on paulos zet. The resistance should be 47k each. Also a different coil can be used like deflection yoke coil. Don't need to wound, it's ready to use. I think putting the signal after a 4,7nF cap isn't the best place. Sometimes lon wire antenna or am antenna can be used after a coil giving extra energy.
dxer_87
Don't need to use 555 timer kit. Shown here solution will feed the right channel. The transistor with cap in the middle changes the current character thus the existing board makes more use of the given signal.
dxer_87
Hello, In US for 110v in subsystem the R1 needs to be higher: 1M ohm. The rest is ok. I have a concept of new power supply for paulos, but not only. This can work for many solution that cannot self loop or are dying out with a load. You may try this solution with some kits.
Greetings!
https://youtu.be/uTgJSddypQ0
