audio amplifier as a power generator (instruction)
Started by dxer_87, September 21, 2022, 03:56:14 PM
dxer_87
a workable 3-phase AC power supply.
I will tell you how in few sentences. Take a Robotron RS2500 or RS2510. if you have good skill in electronics i'll try to teach how to make 3-phase system of an amplifier. sadly only few of amplifiers are good for these because of mounting. there is another trick called 'grabber' that you wound around the existing transformer with insulated cable. but i think 1000 turns are needed to this and old type of transformer. i didn't try with cake transformer (toroidal). then you make step up with transformer. this is phase 'G'. Phase 'B' you get as in standard and Phase F is step up after the coil on right channel (needs to be triggered with 50hz not 1khz, but use a 2.5v overload and tune the resistors in right channel). you still use voltage doubler to hold the ps. so you need at all 3 step up transformers :). and the R S T i equal to G F B. though the phase are not superb in degrees, this needs tu be tuned a bit. i don't know how to measure phase degrees, maybe with a scope... this gives only a 1-1,5 kwatt of power, but 3 phases :D, so you can run a motor that runs an 3 phase 10kwatt AC generator (qmogen) and have household powered. give it a try :) stereo is enough. the only problem for grabber is how transformer is mounted. But Robotron RS2500 is OK. I've managed to build such 30 years ago for an amateur of strange inventions ;).
Ps. you may use even two thick coils to have even more current.
ps.2. 3rd channel is rather used to play captret signal for alu covers of capacitors. You play it loop from mp3. 8hz noisy beeps are the best. like the one used to set brain into alpha state. here you use 4,6,8 and 12Hz only, https://mynoise.net/NoiseMachines/binauralBrainwaveGenerator.php record and play loop at maximum volume. again correct resistors in third channel to get more voltage on output. use a soundcard without hum noise cancelling (some laptops use this, try on ATX). Then you connect the signal to most of the big caps around (easier for older units).
and how the right channel should be:
dxer_87
Latest version of my instruction :) Corrected few details.
panyuming
dxer_87
Sadly I received only one donate. I was calling my bank, and they claimed they did not received any infos on servers about any donations...Gross...
I will expand this instruction with more tricks soon. Don't worry, everything will be alright. I started writing my own handbook about free energy also.
sm0ky2
Quote from: dxer_87 on September 23, 2022, 01:59:57 PM
I have some images how I wound the coil. Yes in Poland we say radiator for heatsink. Sorry for my weak language. I am still learning.
I don't know where the overunity comes from in this system, but I think it's very easy to do. You may adjust both channels using Daqarta program and a computer with soundcard that does not cancel 50Hz noise (most modern laptops mute this frequency at the level of a soundcard). Maximum frequency for left channel is  (50,100, 200, 400Hz) 600Hz and for right channel that should be loud hiss. Once I did a 2V whistle of 2 transistors for this channel, the freq. should be sth like 1-1.3kHz with a triangle or sawtooth, it doesn't matter much, though it needs to be loud as hell. Also modifying the amplifier that it will give higher voltage on the right channel is well seen (exchange some resistors for lower in most cases), then you give from RIGHT SPEAKER OUT a coil with about 5000 turns of wire simply wounded on a ferrite core (i always take enameled wire from OLD TV - the one around the screen), put into a voltage doubler and via schottky into plus of a power supply. also good technic is to wound phase wire before it goes into transformer around the capacitors with insulated cable. then some voltage induce in the caps. There's also special signal to captret the caps (to treat their tops with special signal, I know the specification of this signal and I will describe).
I'll try to describe this technology as good as I can. I was fighting more than 2 years to remind, especially how I was making the booster, because most projects on this topic I made in my childhood in the attic and I almost forget it all. And that audio stuff is easiest method to achieve free energy. I had also successes with combining Kapanadze coils with amplifiers as a teenager. I'll try to describe this aswell. I am sure this technology like SR193 or Dally really works, cause I was succesful in making this stuff.
Put some cents for me, so I may normally live. I live on social, no work, cause I am much Ill (neurologists and psychiatric problems :/).
I swear, I'll share the infos ;) I had one video, but It was in polish language. I'll try to make english version :) ). If you have spare time, spare amplifier and parts and understood what is in the steps. You will succeed with free energy.
Yours sincerely Przemek.
In America we would use: 60Hz, 120, 240, 480 etc.
I think we know where the noise is from
