audio amplifier as a power generator (instruction)
Started by dxer_87, September 21, 2022, 03:56:14 PM
dxer_87
Last changes in Jawik: You may use another smaller coil and try to get into voltage resonance.
dxer_87
Hello!
I updated my instruction, but still many things to say. There are other tricks with tape recorder motor with little magnets near transformer i.e. (like Yasir Experience channel) or gathering energy in right channel by an antenna into fat coil. You can then tune this antenna to gather energy on specified bands. I was trying this years ago, but have no idea how to achieve this again. I was surely using 27MHz crystal, 465kHz yellow resonator and some transistors - application for this. Only long wire antenna. Also i as wounding special winding for each freq. on fat coil.
I was thinking about this Jawic today, and probably would be better to connect coil on emitter, but why not using another little coil of lower inductance. Also i was calculating specified voltage resonance, that gave me some reasoning for the values of capacitors.
dxer_87
In Jawik 5 for lower resonance frequency and lower inductance use 68nF C3 capacitor.
dxer_87
If you think of a Paulos to cut your power bill, and don't know what to do, you may try caplos system that utilize only three parts:
dxer_87
I know that this is not the topic for Qmogen, but let's treat this topic as my own little room here. I want to share with you what I found in my childhood about classic motors. You may give little 220nF/400V cap between neutral and S phase or between neutral and case. I don't remember this exactly. Should start with more ease. Also the quality of groundings count much in this solution.
