audio amplifier as a power generator (instruction)
Started by dxer_87, September 21, 2022, 03:56:14 PM
dxer_87
Everything depends on your effort, the skill is a minor thing.
dxer_87
This system I was also connecting once upon a time. If caps are used the motor consumes much less energy for itself work.
dxer_87
Using heater my friend asked me:
I can NOT see any power SAVINGS by using CAPLOS.
How can that be?
Can You explain?
Answer:
so here is the answer, https://www.nrel.gov/docs/fy21osti/78472.pdf when you use on the whole installation the power is much mixed, there should be savings, but it depends on this triangle. those are three different loads or maybe even three types of electricity... and in your case its a pure active power, hard to dim, especially on S phase used in one phase installations. Try on R or T if you have such possibilities. Try on non RCD installation input/output. The resistor may i gave in schematic 5ohm/100W. May be better. I don't know. The capacitors capacitance count much too. What my friend was testing he found special average values for typical installation which i shown in my first caplos picture.
dxer_87
dxer_87
