An energy harvesting project
Started by JulesP, November 03, 2022, 04:04:41 AM
dsquared18
Hello Julian,
Must say this is a very interesting project and I'm impressed by the detail and style of your interim work.
One thing I'm not clear on is whether you have used bifilar coils, a la John Bedini, or (as seems more likely) just a single wire? Also, do you think you would notice a difference if the other style coil was incorporated?
Looking forward to seeing your final report.
Best Regards,
David
dsquared18
It's been a while Julian... Hope you are well.
How is this going? What are your plans?
All the best,
D2
JulesP
Hi Dsquared,
There was so little interest from this site that I stopped posting and stuck with just the 'energy science forum'. Hence I have only just seen your PM.
To answer your question, all my coils are single wire and my trigger is a Hall sensor. I did build a trifilar 'litzed' wire coil originally but I found the tuning difficult and went for the sensor instead. Using that my rotor accelerates up to about 3,250rpm. However, I will be experimenting with a single bifilar coil soon with a PCB-based original Bedini circuit. This may seem like going backwards but I came into all this from a tangent and didn't build a conventional' SG machine like so many others.
My research rig is designed to test and explore a wide range of factors but first, it would help to experience what JB did (also see below) as he went to great lengths to make it straightforward to replicate.
To summarise the current state of affairs, the predicted power outputs based on the earlier obtained CoPs did not come to pass, which begs the question of what was happening that caused those very clear and pronounced results.
I am making adjustments to my setup, such as modifying cap dump circuit to a 'low sided' version and changes to the coils to 'backtrack' in a sense to get the sort of results from the original SG machine obtained, and then work back up to find what results in 'radiant' effects and what doesn't.
I am also now working with someone who has achieved such and has a patent out on and more to come regarding an energy/charging system on the basis that I will acquire the 'palatable' scientific evidence of what his group has observed for years and in a repeatable way. I've signed an NDA so don't ask who, what, and where 😉
However, they are aware of my role in presenting such info and details for replication by anyone out into the open, so it's just a question of the timing of what is put out and when.
Did you get to see the 'replication manual'? I completed this in the spring to allow anyone to replicate what I achieved up to March this year.
If not, the manual and a lot of Appendices material can be found at:
https://mega.nz/folder/YUM0nLoT#bYpLIazqMM5K2IrEQjghDQ
There is a lot there to interest the researcher, including my other related interim reports and papers from others regarding challenges to the 2nd Law etc.
Over the next few weeks, I will be writing a document on how to measure the various outputs from a rotary-based system, namely the receiving battery, the rotor, the cap dump system and a rotor energy extraction system. This was covered in the SG-2 ebook but I think there's a lot more detail that would be useful to the serious researcher, whether or not 'radiant' effects are being observed.
But when they finally appear, it will be very handy and, of course, this material will be added to the updated manual, whenever that comes about.
Julian
dsquared18
Thanks for your reply Julian...
I'm surprised that this forum hasn't shown more interest - one of the few highly detailed attempts to produce the effect everyone here is looking for!
Quite a 'mystery detective' story you paint (sorry to mix metaphors), but I'm glad to hear you're still 'on the case' - and getting some synergistic help also (no, I won't ask).
I have seen 'a' manual - from January. Have you an updated 'spring' version then?
I look forward to reading more of your findings and advice, but in the meantime I will check out the energy science forum.
Wish you great success and thank you once again for your efforts!
All the best,
D2
bistander
Quote from: JulesP on June 24, 2023, 11:28:28 AM
Hi Dsquared,
There was so little interest from this site that I stopped posting ...
Julian
Hi Julian,
There was interest but lack of understanding why you ignore my simple request. I assumed you had done the test and realized true result. So again, please do the following test. Thanks in advance.
bi
Quote from: bistander on November 06, 2022, 03:07:37 PM
To demonstrate COP > 1, do this.
Start with two batteries, identical.
B1 is fully charged (100%SoC). B2 is partially charged (80% SoC).
Place B1 as Run battery. Place B2 as Receiving battery.
Run system until B2 is fully charged, to 100% SoC.
Switch (manually) B1 and B2.
Run until B1 is fully charged, to 100% SoC.
Switch B2 and B1.
Run until B2 is fully charged, to 100% SoC.
Switch B1 and B2.
Repeat as long as you can.
If the needed run times decrease with each cycle, you have something interesting.
If you are soon, after a few exchanges of B1 and B2, unable to reach 100% SoC on the Receiving battery, COP < 1.
bi
