Magnetic Graphite (Oxford Bell)
Started by clearchrome, November 09, 2022, 08:09:32 PM
kolbacict
You could get more by rectifying  radio noise.
especially if you are near a broadcasting station. :D
Jimboot
I can get over 1 volt with paper towel, carbon, and either Aluminium or gal steel no electrolyte but needs humidity. can run a calculator with 2 of them. needs 3 or 4 though to get an led to glow. Lower voltages on copper and SS . https://youtu.be/jBQg4GA8014
kajunbee
When I was experimenting with aluminum air batteries I found that graphite felt worked well. But I had better results if I treated it first. I tried different things but boiling it in muriatic acid first and then rinsing and drying seemed to work the best. I'm not sure why it helped but I suspect there was a coating from the manufacturing process that got stripped away.
sm0ky2
Nigel Cooper demonstrated that 2 diodes in parallel, with one in reverse direction
can draw stray currents through any large conductor, lighting the diodes indefinitely.
No electrolytes, no chemical reactions.
But back to the topic: The Oxford Bell (and similar devices)
See this:
https://en.m.wikipedia.org/wiki/Zamboni_pile
clearchrome
Quote from: kajunbee on November 12, 2022, 06:35:07 AM
Thanks, I will try that. so the paper towel just uses your local humidity?
