Thanks to ALL for your help!!
New free energy developed in Maldives
Started by tomd, November 10, 2022, 02:44:52 PM
ramset
Jim
Thanks to OP TomD 👍
Video again from post 1 here
https://m.youtube.com/watch?v=nAk8MagnDsY&feature=youtu.be
8:50 mentions Malcolm Bendall
10 :25 starts info on methodology
11:30 ? Mazda investment
And thanks to Jim for doing what he does ... connecting with inventors !
Respectfully
Chet K
Thanks Grandma
sm0ky2
If you think of a 'charge' of known value in free space as having a discrete "volume"
And undisturbed charge would carry a frequency component, whos wavelength is equal to any dimension of that volume.
Adjust for the medium, and this exists even here on earth.
If you want to see an example of the math on this:
it is exactly the inverse of the modulation waveform used to stabilize the containment fields that contain the charge.
ramset
Jim
From links
Some seems older info....since Randall said it's been in works for 7 years ( or at least
Since he was made aware and promised public silence)
  Since past summer they had all patents,licensing etc established,
Then gave Randall permission to talk publicly and about releasing open source in 3months ! ?
Snip"
1. Plasmoid Power -
This company was a originally established to manufacture ceramics for Derlite's manufacturing facility in Thailand. It has been used as a vehicle for the development of a ground breaking technology that enables the harnessing of energy from water. The company was established as a joint venture with Malcolm Bendall, a scientist in energy recovery system research. Alpha Prospects holds 51% of the equity in this company.
End snip "
EDIT to add ( this "how it works " below sounds a bit like other water fuel claims
Extreme Example: "Herman Anderson water car" and there are many others!
Snip"
How It Works:
The engine is started in the usual manner using diesel, petrol or LPG with the exhaust gases passing through a reaction chamber. Once the engine and containment vessel come up to an operating temperature - around 350°C - the alternate fuel is introduced. The alternate fuel (plasmoid) is initiated when a preconditioned water and air mix is passed through a container that atomises and vaporises the water using stainless steel as a catalyst. The plasmoids harvest the electrons and protons from the protium contained within the water and these are then used as the fuel for the engine
End snip"
Also from Links provided by Jimboot to mage of plasmiod engine below ( would be nice to have some text about that engine?)
Video again from tomd first post here .
Respectfully submitted
Chet K
Thanks Grandma
sm0ky2
@chet
Their device in a very technical sense (without the invention of meaningless terminology)
Is exactly like the ultrasonic vapor electrolysis being experimented with on the other forum.
